Air flow problem... - JeepForum.com
post #1 of 5 Old 07-17-2010, 08:27 PM Thread Starter
Tassadar
Tassadar's Avatar
Air flow problem...
Well, my Jeep Wrangler suddenly started to have problems with air-conditioning air flow. The air seems to come out the bottom (feet) portion only. Turning the knob will not cause the front portion to fire up. Turning the knob to any of the positions does not matter. But here is the odd part, occasionally when starting the Jeep, the air will kick out the front on it's own (ie. when air conditioning is on).
Now I do not think it is a disconnected hose (I think!) because if it were so, when I turn the knob from "feet only" to "front only" should cause the air flow on the feet region to go off or at least slow down. But the flow does not modulate at all... I am not sure where/what to start looking at. Please advice
CC
Tassadar is offline
post #2 of 5 Old 07-17-2010, 10:16 PM
cntp
There is a little door valve thingy (I can only think of "Blend Door", but I think that's the one that controls heat vs ac), way behind the dash somewhere I'm sure, that controls where the air goes. It's vacuum operated I believe. It's default position (I think via a spring) is defrost, then going to floor and then dash vents. My guess, either this door is stuck, or you've got a vacuum leak that is not allowing it to turn all the way to dash vents position.
On my old Grand Cherokee, I had a vacuum leak somewhere (never took the time to find it), so if I was crusing down the highway and hit a hill, the A/C would move from the dash, to the floor, to defrost, depending on how steep the hill was. Once I was at the top of the hill, it went back to the vents
Drew, KJ4MUZ
cntp is offline
post #3 of 5 Old 07-17-2010, 10:23 PM
thirdeye
Keep the A/C in the off position and take off your doors and top!
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #4 of 5 Old 07-17-2010, 10:27 PM
Mino
This happened to me before when I accidentally disconnected a vacuum hose right under my throttle body. Check it out. Good luck.
'05 Jeep Wrangler X
Rocky Mountain Edition
3" suspension lift, K&N cold air intake, Pro Comp MX6 shocks, JKS Quicker Disconnects & Front Track Bar, Dynomax Cat-Back system, SYE kit, Pro Comp Rock Crawler Wheels, 33" BF Goodrich A/T, Aussie Locker, and Warn XD9000i winch
Mino is offline
post #5 of 5 Old 07-18-2010, 12:57 AM
Sccafire
That would be called the "mode" door
Scott
"life is good at 2 MPH"
Sccafire is offline
a/c , flow , vent
4.2 coolant flow problem cosmo_j YJ Wrangler Technical Forum 3 08-19-2009 03:05 PM
HVAC air flow problem Telefunken72 TJ Wrangler Technical Forum 1 06-01-2009 09:08 AM
Fuel flow problem? YJ88 YJ Wrangler Technical Forum 2 03-12-2009 02:54 PM
Water flow PROBLEM!! badazzpolaris YJ Wrangler Technical Forum 8 07-06-2008 03:03 AM
Fuel flow problem merlin7782 YJ Wrangler Technical Forum 6 07-18-2007 12:59 PM
