air flow control door in the HVAC system - JeepForum.com
post #1 of 5 Old 10-01-2010, 05:40 PM Thread Starter
LiveAndLearn
I figured it out this hanging motor actuates when I switch from dash to floor. This is going to be important in the winter I guess lol where should I get one of these?
also in the picture, the plastic piece at the end of the arm is broken, the motor still works fine. Could I possibly need a new door and not the motor? And where does this thing mount up?
posted this in another thread with a different title, wasnt expecting to be talking this much about it so I made a new thread with an accurate title.
Thanks guys.
Hunter
LiveAndLearn is offline
post #2 of 5 Old 10-01-2010, 07:48 PM
rnolloth88
Sounds like you are gonna need to pull the dash.Remove the heater box and replace the blend door.Very common problem
rnolloth88 is offline
post #3 of 5 Old 10-01-2010, 10:50 PM Thread Starter
LiveAndLearn
fml i really wish i didnt have to take off the whole dash
post #4 of 5 Old 10-02-2010, 12:01 AM Thread Starter
LiveAndLearn
any how-to's on this?
post #5 of 5 Old 10-02-2010, 06:33 AM
rnolloth88
It's not a terrible job,at least not for me but i've also done a bunch of them.You have to remove the steering column,locate all the bolts for the dash once you get the dash out the bolts for the heater box are on the outside of the jeep on the firewall.You'll need to reomve the heater hoses and unhook the ac lines which actually takes a special tool.Be sure you have someone evacuate the ac system before you unhook the ac lines.Overall not a bad job but as i said i've done a bunch of them.If you get into it and got any questions let me know and i'll help ya along.
High Flow cooling system. Help STEVIEFOO TJ Wrangler Technical Forum 12 09-06-2010 03:42 PM
HVAC air flow problem Telefunken72 TJ Wrangler Technical Forum 1 06-01-2009 09:08 AM
HVAC Control acrijos TJ Wrangler Technical Forum 1 12-09-2008 01:37 PM
hvac system dosen't work?? drew76924 TJ Wrangler Technical Forum 3 10-30-2006 11:15 AM
HVAC control Polaris TJ Wrangler Technical Forum 0 04-19-2004 05:15 PM
