Air conditioner line puncture. Will JB weld work?? - JeepForum.com
post #1 of 4 Old 06-26-2005, 11:18 PM Thread Starter
docsayler
First off, I am new to this forum, so Hello All. My question is I have a small pinhole on my air conditioner line and all the 134a leaked out. What I am wandering is if something like JB weld would work to seal the hole. The hose I am refering to is the one that comes out of the top of the compressor. Its a 1997 4.0. Any help would be appreciated. Thanks
docsayler is offline
post #2 of 4 Old 06-26-2005, 11:32 PM
Stu Olson
Stu Olson's Avatar
If that is the high pressure line, it will be seeing pressures in the range of 300~350 PSI. I'm not sure if JB weld would hold up to something like that.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #3 of 4 Old 06-27-2005, 01:25 AM
TJ-n-Oregon
TJ-n-Oregon's Avatar
Stu is right. I doubt JB weld would hold the pressure on that line. Have you priced just replacing the line and orings? I wouldn't think it'd be that much.
'02 TJ Sport with a few mods
'95 XJ with a few mods'
TJ-n-Oregon is offline
post #4 of 4 Old 06-27-2005, 07:30 AM
blupupher
blupupher's Avatar
Nope, JB weld is not made for pressure situations. And it does not bond well to aluminum. You need to either replace the line (recomended) or have someone who welds aluminum weld the hole.
Either way, you need the A/C system serviced by an A/C person, because the system will need to be evacuated and re-charged.
blupupher is offline
does my jeep yj have air conditioner and if it does how do i basically make it work? tank07 YJ Wrangler Technical Forum 44 08-26-2009 12:34 PM
Does JB Weld work SolidBrass TJ Wrangler Technical Forum 2 08-20-2009 10:24 PM
fuel line help before work in the morning yj_beater51 YJ Wrangler Technical Forum 10 07-02-2009 11:33 AM
Line-X on bumper and bumperettes.....howd that work for you? xtremescootr YJ Wrangler Technical Forum 17 03-04-2009 04:51 AM
Side Wall Puncture repair??? H2RecoveryTeam YJ Wrangler Technical Forum 8 05-15-2006 01:40 PM
