Air Compressor - JeepForum.com
post #1 of 16 Old 05-09-2006, 06:48 AM Thread Starter
JQlaxTJ
Air Compressor
I'm about to buy an air compressor, but i don't know which one would be best for working on a Jeep. I found a combo from home depot and it comes with tools too. What do you guys think?
http://www.homedepot.com/prel80/HDUS....jsp?pn=168916
Thanks guys.
JQlaxTJ is offline
post #2 of 16 Old 05-09-2006, 06:50 AM
dos0711
dos0711's Avatar
1978 CJ5
Link just takes you to Home Depots home page
2000 Wrangler TJ, 4.0 6 cyl, A/T, G2 Dana 44s, ARB Lockers, 4.10 ratio
dos0711 is offline
post #3 of 16 Old 05-09-2006, 07:04 AM Thread Starter
JQlaxTJ
Sorry about that. Just fixed it.
JQlaxTJ is offline
post #4 of 16 Old 05-09-2006, 07:13 AM
CNY
What does "SCFM" mean. I'm guessing something cubic feet per minute. What's the "S"?
CNY is offline
post #5 of 16 Old 05-09-2006, 04:53 PM
WOLFSTER
The compressor will be adequate for the average homeowner. Realize that the impact wrench and air chisel wont be able to run continuous. You'll have to let the air pressure build up. See if they have a pkg with a bigger compressor if you're unsure.
WOLFSTER is offline
post #6 of 16 Old 05-09-2006, 06:02 PM
ASUsax
STANDARD Cubic Feet per Minute
So the volume is measured as the amount of space the air would take up at room temperature and standard pressure.
That's a big compressor for a home. More than adequate for most tasks. You aren't going to run a car repair shop in the garage, so I wouldn't worry about having to wait at times to use some tools.
Blue Jeep Club Member #197
'02 TJ - 33" BFG MT's's, some armor, yadda yadda. 2" BDS lift/1"BL
'94 ZJ - May it rest in pieces.
ASUsax is offline
post #7 of 16 Old 05-09-2006, 06:57 PM
mikevsgeek
I have a very similar Husky 26gallon tank and with all the times I've used my 1/2" imact-wrench I have never had to wait for the pressure to build up to keep using it
mikevsgeek is offline
post #8 of 16 Old 05-09-2006, 06:59 PM
phydeaux
Originally Posted by JQlaxTJ
....What do you guys think?
Thanks guys.
That's basically what I have. Mine's a Campbell-Hausfield. It's adequate for most things. Like others said, you will have to wait on pressure if you want to do much sanding or grinding or stuff like that. It's great for most things.
Thumbs up from me.
'98 TJ Sport, 4.0, 5 spd., 3.73's; 4" RC Series II Lift; 33's, Daily Driver.
Life Member Hummer Recovery Team.
Just
Empty
Every
Pocket
phydeaux is offline
post #9 of 16 Old 05-10-2006, 05:30 AM
Scott_98TJ
The CFM ratings are also on the tools. The need for air volume increases dramatically with things like sprayers (hvlp) etc... Read what the tool ratings are that you want to use, and then look for a compressor. Most package deals tend to be on the low duty cycle side.... an "average" approach for sure. I'd not go with an oil-less setup if possible.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
post #10 of 16 Old 05-10-2006, 05:40 AM
CNY
Originally Posted by Scott_98TJ
.... I'd not go with an oil-less setup if possible.
I read that a lot. Why? Again, we're not running a business with these things.
If you have an oil compressor, do you need a special dryer setup for the air?
CNY is offline
post #11 of 16 Old 05-10-2006, 07:17 AM
DogPak
DogPak's Avatar
I have a similar Coleman oilless compressor that I got at Cosco. Has served me well for working on the Jeep and cleaning things off but one thing about the oilless is they are quite loud.
'02 Sport, I6, 5spd., D44, 3.73 gears, SYE, CV Driveshaft, OME HD suspension, 31x10.5 Maxxis Bighorns on AR 767's, JKS Quicker Discos, Warn 8000i winch, 4xDoctor rockers, Steves Jeep Fab R. bumper-tire carrier, Top Five roof rack, ORF bolt in cage, skids front to rear.
DogPak is offline
post #12 of 16 Old 05-10-2006, 07:47 AM
khokhonutt
Depends on how you use it, but from what I read the oil-less systems don't hold up as well to continuous operation. When I got my compressor I figured I didn't have the space or money for a huge setup, so I went with what I thought was a fair priced oil compressor. That way I could hopefully make up for the lack of tank size with the ability to constantly feed an air grinder, for example.
This is the compressor I went with. It, and others like it, can and will run pretty much all day without an issue.
Sears item #00919541000 Mfr. model #19541
I also picked up an inexpensive air tool setup from Sam's club. It was like $70 for 4 tools. So far it's held up fine for what I do.
Jeff
khokhonutt is offline
post #13 of 16 Old 05-10-2006, 08:03 AM
honaker
SCFM Standard cubic feet per minute.
Standard air Air at a temperature of 68 F, 14.70 PSI atmospheric pressure, and relative humidity of 36% (per ASME). In the gas industry, temperature is 60 F.
14.7 is atmosphjeric pressure at sea level
'04 Unlimited
'99 Sport
honaker is offline
post #14 of 16 Old 05-10-2006, 08:08 AM
04 Unlimited
04 Unlimited's Avatar
2015 JK Wrangler
I bought a Sears oilless compressor several years ago. I really like it. I don't use it all the time but it comes in very handy from time to time. My only complaint is that it is LOUD. If I ever buy another one, it will probably be the old style lubricated type. But, other than the noise issue, go for it. You'll be glad you did.
2015 JK Unlimited, White, Auto
RIP LJ
04 Unlimited is offline
post #15 of 16 Old 05-10-2006, 08:15 AM
RockRunner85
Do NOT buy that compressor. My friend has the exact same model. POS and its sooo damn loud. You can't talk over that thing when your in the garage with it running.
Go with an oiled compressor. You'll be much much happier and they last forever and most have 100% duty cycle so you can use it for painting etc if you need to.
I have a 26gal 110v compressor from Home Depot (pictured below). Costs around $380. It puts out 6.6 at 40 psi and 5.8 at 90 psi. That is just enough to run a cut off wheel continously or use a HVLP sprayer continously. I have ran it for 2 hours straight and never had a problem. Just make sure you change the oil when it says. It takes less than a cup of oil.
If I was to buy another I would go the 220v route. There only 50 bucks more and if you can do the wiring yourself or don't care to pay to have 220v installedin your garage its well worth it. Double the tank size and CFM output for only 50 bucks more.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
ARB Compressor and set up ryne0149 TJ Wrangler Technical Forum 2 03-24-2008 03:56 PM
A/C compressor coverted to air compressor rwcook49 YJ Wrangler Technical Forum 9 09-13-2006 02:31 AM
Sanden compressor or electric compressor? Collins72 TJ Wrangler Technical Forum 3 11-15-2004 05:38 PM
Sanden Compressor Clutch work on a York Compressor? Stricken TJ Wrangler Technical Forum 2 07-14-2004 11:55 PM
A/C Compressor convertion to Air compressor E_ROCK YJ Wrangler Technical Forum 3 07-02-2003 06:06 PM
