ahh clink clank stupid control arm bolts. - JeepForum.com
post #1 of 4 Old 08-03-2010, 12:27 PM Thread Starter
jalbs
I was wondering why in reverse if I hit a bump it would clank. I can move the rear upper control arm bolts by hand. These have never been touched so kinda odd but with all the work I did with JKS front/rear trackbars and quick discos should only take an hour max. Anything I am missing since I have seen conflicting info on the actual bolt sizes. m10x1.5x 80 to m10x1.75x???
06 Jeep Rubicon 6spd SWB
2.5" RC SL and 1.25" BL
285/75-16 Mickey Thompson MTZ
Currie HD steering
JKS Front/Rear track bars
JKS quick discos
jalbs is offline
post #2 of 4 Old 08-03-2010, 01:53 PM
-dirt-
The bolt size is M10x1.50x78.20. <--- This is from the FSM.
If they are flopping around, its sounds like the bushings may be shot.
-dirt- is offline
post #3 of 4 Old 08-10-2010, 08:53 AM Thread Starter
jalbs
yeah they are shot I dont want to tighten it and bend the actual control arm metal.
Question:
Why do I still have severe bump/torque steer? I raised the T-case, aligned the axle don't have any vibes that I can notice. If at say 65mph I let off gass it pulls right and accelerating it pulls left. could it be the shot bushings in rear control arms?
I appreciate any response as this is my DD and need to drive on highway every day. As it is now I don't think it is safe!
Currie HD steering
JKS quick discos
jalbs is offline
post #4 of 4 Old 08-10-2010, 09:07 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Question:
bad control arm bushings are going introduce axle wrap and throw off thrust angle. the axle isn't going to want to stay perpendicular to the frame.
bump steer and torque steer are two different things. don't confuse them.
you can't bend the "control arm metal" by tightening the bolts. the Clevite bushings have a sleeve inside them. the bolt squeezes on the sleeve, making it immobile, the bushing acts as the pivot & cushion.
To replace the bushings, some people burn them out. Then collapse the housing, pull it out and press in the new one with a BFH.
I didn't want to make a huge mess, so I made a bushing press: http://www.jeepforum.com/forum/f9/un...ml#post9547610
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
control arm , lca , bolt , tj , wrangler
Want to replace stock control arm bolts with grade 8 bolts... Mino TJ Wrangler Technical Forum 7 01-23-2010 10:02 AM
Can I use stock control arm bolts on Rubicon Express control arms? LGriffith TJ Wrangler Technical Forum 2 01-10-2010 01:11 PM
stupid torx bolts tcox TJ Wrangler Technical Forum 21 01-09-2007 07:35 PM
Clankety Clank Clank Foehammer TJ Wrangler Technical Forum 3 09-23-2005 07:41 AM
stupid bolts.... Stock88YJ YJ Wrangler Technical Forum 5 10-14-2003 02:35 PM
