Aftermarket tailight guards - JeepForum.com
post #1 of 7 Old 02-05-2004, 12:41 PM Thread Starter
Pinebarrensboy
I was looking around at some old posts and it seemed like these are kind of a chore to put on. The ones I bought are from JC whitney, they are the ones with a solid back plate and 4 bars that wrap around the light with 3 screw holes and one larger hole for the wire harness. Anyone know of a website that covers this or has anyone here installed them yourself? Thanks in advance.
Brandon
2003 Rubicon
2.25" Budget Boost / Skyjacker 7000 Hydros
265/75/R16 Goodyear Wrangler MT/R's
JKS Quicker Disconnects
Pinebarrensboy is offline
post #2 of 7 Old 02-05-2004, 12:45 PM
Jeeper-4-Life
I put a set on kind of like the ones you described in under a half hour. Probably one of the easier mods.
Jeeper-4-Life is offline
post #3 of 7 Old 02-05-2004, 12:48 PM
SirGCal
RIP
SirGCal's Avatar
It really depends on what type you get.. The ones I got were really easy with basic hand tools.. you just removed the tail light, slid the protector over it and re-installed the light. The trickiest thing was getting the lense back on with the protector in place.. but it was farily easy..
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #4 of 7 Old 02-05-2004, 01:26 PM
seany425
seany425's Avatar
It's a pretty easy mod, once you know what to do should take a half hour or less. The driver side goes in fine, you take off the taillight and dissconnect the wire so you can install the guard there will be foam padding around the connecter plug you will have to remove that and i reccomend wrapping it in electrical tape after you put it back so that it will stay together tight and water cant get into it. The passenger side is a little more of a pain but not too bad once you know what to do. Your wire should be shorter on the passenger side so that you can't pull the light out all of the way. Mine was, and thanks to the advice from someone on here, I pulled back the plastic wheel well molding from the rear passenger side and you should be able to get up inside to the wiring plug, and then repeat the same steps you did for the driver side. Hope this helps
seany425 is offline
post #5 of 7 Old 02-05-2004, 02:24 PM Thread Starter
Pinebarrensboy
Thanks for the replies guys!
Brandon
2003 Rubicon
post #6 of 7 Old 02-05-2004, 02:47 PM
1BadTJ
1BadTJ's Avatar
I had (still have) the taillight gaurds you are talkin about. Installation isnt bad but mine started to rust. Pulled em off and put in led's for the same price. If anyone wants to buy the guards pm me. $20
1BadTJ is offline
post #7 of 7 Old 02-05-2004, 07:53 PM
redrubi04
I didn't have any more trouble with one than the other, but all you have to do is take of the red lens, unscrew the black housing, and then slip the guard over it. It can be kinda tricky to screw it all back together but not very hard overall.....Good Luck!
- Andy
2003 Flame Red Rubicon
1" BL, 3" BDS, 2" RE Spacers, JKS Disco's, 35" BFG A/T's, etc.
RED JEEP CLUB MEMBER #87
redrubi04 is offline
Rocker Guards for aftermarket fender flares YoungGunTJ TJ Wrangler Technical Forum 10 01-11-2010 04:13 PM
Aftermarket Tailight Wiring Problem muskyslayr TJ Wrangler Technical Forum 3 11-23-2008 09:18 AM
What AfterMarket Rocker Guards to get? BigBLue05X TJ Wrangler Technical Forum 56 01-22-2008 01:20 PM
Removing sidesteps and tailight guards... bjjfoshizzy TJ Wrangler Technical Forum 15 07-01-2005 08:34 AM
Chrome tailight guards? bjjfoshizzy TJ Wrangler Technical Forum 8 06-29-2005 12:20 PM
