aftermarket seat brackets - JeepForum.com
post #1 of 5 Old 06-28-2010, 02:46 PM Thread Starter
leolufse
I'm kicking around the idea of picking up some aftermarket seats. My question is about the seat braket adapters. Since they reuse the stock sliders, does this mean the seats will still pivot and slide forward like the stockers? If so do they reuse the pull cable on the side of the seat or what?
Thanks in advance.
leolufse is offline
post #2 of 5 Old 06-28-2010, 02:52 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Yep! With corbeau seats your stock slider is taken off your seats and put on the new adapters you purchase from corbeau.
GOLENJEEPTJ is offline
post #3 of 5 Old 06-28-2010, 02:53 PM
GOLENJEEPTJ
Might help? Corbeau Build My Jeep
post #4 of 5 Old 06-28-2010, 02:54 PM Thread Starter
leolufse
Thanks. Meanwhile I found the answer to my question by searching and came across a post of yours. Do you have any pics of you install? What seats did you go with?
leolufse is offline
post #5 of 5 Old 06-28-2010, 02:57 PM
GOLENJEEPTJ
Yep I thank there is some in my Gallery.
seat bracket
Where can I buy aftermarket Front Upper CA brackets pbj-tj TJ Wrangler Technical Forum 6 09-16-2009 02:01 AM
Do aftermarket bumpers require frame tie-in brackets? bruker TJ Wrangler Technical Forum 10 04-05-2007 10:06 PM
Custom seat brackets for aftermarket seats?? NH Jeep Junkie TJ Wrangler Technical Forum 2 01-30-2007 09:55 AM
seat brackets mag162 TJ Wrangler Technical Forum 4 01-18-2007 12:19 PM
Seat Brackets 98JEEPTJ TJ Wrangler Technical Forum 1 10-27-2005 10:05 AM
