Aftermarket Fuel Gauge after 4.3 swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Aftermarket Fuel Gauge after 4.3 swap
The ULTIMATE "Selectable" Locker System! BroughRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits WJ Modular Recovery & Bull Bar Relocation Packages
Unread 04-20-2014, 07:32 PM   #1
GoodtimeKenny
Junior Member
GoodtimeKenny's Avatar
I did my 4.3 swap and everything is ready and running....but the fuel gauge. I am running Equus 8000 series gauges, the fuel gauge is for a Chysler sending unit. The gauge is supposed to read 10ohm full and 75ohm empty, problem is the chrysler sending unit is putting out over 200ohm. Has anyone done this swap and had issues hooking up a fuel gauge?
GoodtimeKenny is offline   Reply With Quote
Unread 04-21-2014, 07:12 PM   #2
ky-homelite
No clue, but dang do those gauges look good!
ky-homelite is offline   Reply With Quote
Unread 04-28-2014, 09:08 PM   #3
GoodtimeKenny
Junior Member
Thanks!
Unread 04-28-2014, 09:40 PM   #4
Ryanmccartney
Ok jeeper
Ryanmccartney's Avatar
I have had this issue I found a sending unit from auto wrecker and adapted to existing jeep fuel canister in tank
I did this and high pressure fuel pump when I installed the 5.7
If your gauge is programmable it makes this really easy
Hope this helps
Cheers
Rye
Rye
Ryanmccartney is offline   Reply With Quote
Unread 04-29-2014, 02:31 PM   #5
Jonny Jeep
Jonny Jeep's Avatar
The stock specs for the fuel sender are 20 ohms full, 220 ohms empty.
Other than getting a gauge to match those specs, in order to get the right sort of resistance for your gauge, you could try running a resistor in parallel with the fuel sender to lower the resistance.
A 110 ohm resistor would give give resistances of 17 full and 73 empty.
A 120 ohm resistor would give give resistances of 17 full and 78 empty.
Actual values would differ slightly due to resistance tolerances of the sender and parallel resistor. At 17 ohms you'd probably never see a full indication with a full tank, but you would get a pretty accurate indication of low fuel which is obviously more important. Either one should work pretty well for you.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals (FSMs) and parts lists can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm
If the link doesn't work properly, look for the service manual link under Jeep Resources at the bottom of the page.
Jonny Jeep is offline   Reply With Quote
Unread 04-30-2014, 04:04 PM   #6
GoodtimeKenny
Junior Member
That's the kind of info i have been looking for! Thanks!
