aftermarket cams in the 4.0 - JeepForum.com
post #1 of 21 Old 02-25-2008, 02:22 PM Thread Starter
4.0l sahara
Well I was reading a few articles about cams for the 4.0 and they all said they worked well in the 4.0. I had thought about it before but never done any thing about it. For me the install of it is no prob. I was looking at the cams made for low end and read that this was a good cam for the 4.0
http://www.compperformancegroupstore...tegory_Code=A6
Will this pass emissions in ct? It's not that crazy of a cam so I don't know if it will. Anybody here run one of these and what do you think.
4.0l sahara is offline
post #2 of 21 Old 02-25-2008, 03:58 PM
BlueFlame
BlueFlame's Avatar
Were they by any chance selling cams?
I would think that if they worked well in the 4.0 lots of people would have them, instead of ...roughly.... no one?
BlueFlame is offline
post #3 of 21 Old 02-25-2008, 04:44 PM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
JP magazine has a review this month of improvements for the 4.0 and cams were listed as their best bang for the buck.
Whybu1 is offline
post #4 of 21 Old 02-25-2008, 04:57 PM Thread Starter
4.0l sahara
Thats where I read about them. In most engines cams can help alot. There also not that much $$
post #5 of 21 Old 02-25-2008, 05:00 PM Thread Starter
4.0l sahara
Also if I had to Gauss why alot of people don't have them is because they don't know how or want to dig that far into a 4.0.
post #6 of 21 Old 02-25-2008, 05:06 PM
bigchevyman24
bigchevyman24's Avatar
I would guess that it's because the 4.0L is already a torque monster and is not a high hp engine. Most people would rather spend the money on gears and then the rest on lift/tires/armor/etc...
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #7 of 21 Old 02-25-2008, 05:09 PM
nitecop
From the comp cam link all I got was this: (Online cam specs not available for this cam) when I went looking for the specs on the cam. What are they tring to hide?
Cams for computer controlled engine aren't really all that comlicated. If you keep the can small enough to get good vacume at idle then the computer for the most part will be happy.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #8 of 21 Old 02-25-2008, 05:22 PM Thread Starter
4.0l sahara
Thats the cam they used on the jp web site in the 4.0 I also couldn't get the specs I wanted to see what the lift/duration and overlap was.
post #9 of 21 Old 02-25-2008, 05:35 PM
skyjacked94xj
skyjacked94xj's Avatar
Someone buy one and install it, then tell me what happens... I always wanted to know...
DAILY DRIVER
1996 Cherokee Classic
4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit
CLASSIC TOY
1968 Chevy C-10 short bed
Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list
Project
1988 Pontiac Trans Am GTA
350 TPI | WS6 | 48k original miles | Flame Red Metallic
SOLD: 94 cherokee | Lifted | Locked
SOLD: 97 TJ | 33's | 4.56's | :(
Searching for an Ls-1 Rx-7 project....
skyjacked94xj is offline
post #10 of 21 Old 02-25-2008, 06:32 PM
ToyTJ
2008 WK
"Torque monster"?? I don't think so at 220 foot pounds. It won't spin 33's worth a darn. Even a little 318 Dodge V8 will make a 100 more fp's at only
235hp or thereabouts.
2013 WK2 Overland
ToyTJ is offline
post #11 of 21 Old 02-25-2008, 06:49 PM
Xlr8n
1986 TJ Wrangler
Read further into that issue and you'll find that they had lobes go flat on the very upgrade they recommend! The engine they tested took a crap on them twice and they just had the original put back in the XJ.
The engine upgrade article in the April issue is the biggest source of contradiction I've ever seen.
Xlr8n is offline
post #12 of 21 Old 02-25-2008, 06:58 PM Thread Starter
4.0l sahara
I did read that the comp and crane cams had some probs. Most of there cams are good too. Do they nor harden them alot or somthing? What other cams are out there. I wonder if comp and crane will correct these probs?
post #13 of 21 Old 02-25-2008, 07:14 PM
Xlr8n
1986 TJ Wrangler
The new SM rated motor oils are helping matters with older cam designs either.
Xlr8n is offline
post #14 of 21 Old 02-25-2008, 07:40 PM Thread Starter
4.0l sahara
Why is that? What did they remove or add?
post #15 of 21 Old 02-25-2008, 10:01 PM
04WranglerX
04WranglerX's Avatar
Speak for yourself, I have no problem spinning my 35's on dry pavement posi.
04 Silver Wrangler X
Rubicon Express 4.5" SF, RE Monotubes
AA SYE, Tom Woods DS
35" Yokohama Geolanders on black rock krawlers
Dana 44 rear, ARB air locker, cromo shafts, Dana 30 front, 4.88's front and rear.
04WranglerX is offline
4.0 and 4.2 cams? xjandyj YJ Wrangler Technical Forum 1 10-27-2008 06:45 AM
258 cams? wendell YJ Wrangler Technical Forum 2 06-21-2008 06:35 AM
cams spyder6 TJ Wrangler Technical Forum 5 11-29-2007 03:08 PM
Cams Mudder Shucker YJ Wrangler Technical Forum 6 06-18-2003 11:53 AM
performance cams for 2.5L allaboutjeep YJ Wrangler Technical Forum 2 04-09-2003 08:43 AM
