AEV Tummy Tuck - JeepForum.com
post #1 of 7 Old 03-19-2009, 03:38 PM Thread Starter
outlawjosywales
AEV Tummy Tuck
I got my skid in today & was looking through the instructions. It mentioned some upper control arm adjustment may be necessary to correct any offset pinion angle. I was wondering if anybody that has one of these had to do that? I have adjustable uppers,just hoping it won't be necessary. Running a 4" kit if that helps. Thanks.
Go Anywhere.
outlawjosywales is offline
post #2 of 7 Old 03-19-2009, 03:48 PM
Varnish
Varnish's Avatar
The tummy tuck is equivalent to about 2" more lift for the driveline so I would definitely check your rear pinion angle in relation to the driveshaft afterwards. I'd expect some adjustment would be necessary. I installed my SYE at the same time so couldn't say how much of an adjustment is needed.
'98 TJ, '06 LJ, '88 YJ, '86 CJ, '99 XJ 4dr Ltd
Varnish is offline
post #3 of 7 Old 03-19-2009, 03:48 PM
tobyw
I had to when I installed mine, but I was also installing a suspension lift at the same time so I can't say for sure that JUST the skid would require UCA adjusments. However, since you already have 4" springs with adjustable uppers, I'm guessing you have already dialed them in and you may not have to mess with it any further. Only one way to find out?! Besides, it's easy enought to adjust them, what's the issue? Are yours seized or something?
Jeeps. Lotsa Jeeps...
tobyw is offline
post #4 of 7 Old 03-19-2009, 08:12 PM Thread Starter
outlawjosywales
no they're not seized. i think aev sent the wrong instructions though. i've got a 2001 tj & the instructions say tj-rubicon model. it has how to remove the locker pump & shows a np241 tc. gotta call them tomorrow. the invoice says it's the correct part.
Go Anywhere.
post #5 of 7 Old 03-19-2009, 08:27 PM
brunosplace
Here are the correct instructions for you.
http://www.aev-conversions.com/pdf/i...structions.pdf
Originally Posted by Boodyrider View Post
Big tires, done right, are FREAKING EXPENSIVE. Deal with it, or don't go there.
Originally Posted by woodnjeep View Post
I live in the land where they salt cure roadkill.
97 Jeep TJ Sport, 4.0L, Auto, 3" BDS Lift (SOLD)
98 Jeep ZJ Laredo 4.0L, Auto, Stock
, parted out and scrapped
96 Jeep XJ Sport, parted out and scrapped
brunosplace is offline
post #6 of 7 Old 03-20-2009, 10:22 AM Thread Starter
outlawjosywales
bruno you sir are the man! much obliged!
Go Anywhere.
post #7 of 7 Old 03-20-2009, 02:31 PM
brunosplace
You're welcome, good luck. Take pics of the install!! along with before and after.
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 02:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 05:53 AM
Tummy Tuck powelltj TJ Wrangler Technical Forum 8 12-30-2008 03:03 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 07:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 06:31 AM
