AEV Springs 4.5" vs 3" with RE 4.5 superflex kit - JeepForum.com
post #1 of 4 Old 01-21-2011, 01:59 PM Thread Starter
bonecrushertj
I bought a 4.5" RE superflex kit minus springs and need springs, would you suggest AEV 3" with a 1.25 body lift or 4.5" for running 35's or other suggestions. Looking for best highway ride.
bonecrushertj is offline
post #2 of 4 Old 01-21-2011, 04:49 PM
durango-bob
2006 WK
I would recommend a set of RE 4.5" springs. It seems that the rest of the kit is engineered for them.
durango-bob is offline
post #3 of 4 Old 01-21-2011, 05:20 PM
champelite210
HE wants the AEV's because they are a progressive spring. The 3" with the body lift should be plenty. I'm running RE 3.5 springs only and fit 36 TSL's. I do have tube fenders and longer bump stops though.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #4 of 4 Old 01-21-2011, 07:25 PM
TJRoberto
My built started as a RE superflex kit with 3" AEV springs. Those springs are great!!!. ended up with Currie JJ arms and AEV springs
ps im also running 35" MTZ tires
TJRoberto is offline
Rubicon Express 3.5" SuperFlex with 4.5" Coils ET48 TJ Wrangler Technical Forum 206 01-22-2010 06:55 PM
Anyone Have 4.5" RE Superflex With 3.5" Coil Springs? zener6 TJ Wrangler Technical Forum 6 09-30-2008 06:34 PM
4" RE/BDS vs. 2.5" OME Springs + 5/8" MORE Shackles + 1" Body and/or TJ Flares? KUJeeper82 YJ Wrangler Technical Forum 12 08-04-2007 08:45 PM
3.5" superflex kit or 4.5" superflex w/ 3.5" springs? method84 TJ Wrangler Technical Forum 4 12-23-2005 05:53 PM
Procomp 4" vs. Rough Country 4" vs RE 3.5 Superflex Wheelman TJ Wrangler Technical Forum 20 02-25-2005 12:49 PM
