#1 | |
AEV highline kit and 35"
Hi there,
i'm looking for some experience with different lift kits Just bought 04 Rubi and want to run 35" on it. I was pretty happy with RE staff on my trail XJ for some years, but here is the question: is anybody tried AEV highline kit with let'"s say 2" boost and long trvel shocks to run 35"? I just wan to keep it as low as possible... Also, any thoughts about other brands? Thanks
#3 |
Haulin' Groceries
ome (old man emu) 2.5" lift
soft ride and lcg and you could do a home made highline
Black wont get you back, but Chrome WILL get you home. 1990 XJ Part Outhttp://www.jeepforum.com/forum/f149/90-xj-part-out-2-door-ax15-1301969/ 1978 CJ5Being built 1996 4 Door XJ My DD - Now Parting out |
#4 |
Rubicon Express 4.5" SF kit with 3.5" springs and tube fenders would look killer with 35's
Other Vehicles: 07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs 08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers |
#6 |
Geat tread, btw. Thanks
Thats the idea. LCG is the key, and if high rise fender/hood thing works (it does, obviously), what abot long travel suspention? Just shocks and springs?
#7 | |
with shocks and springs to get the down travel, your going to get lift. Go coil overs and you can get travel without as much lift. What suspensions are you looking at?
Get Savvy |
#8 | |
want it rite or rite now?
the highline and 35's fit well with a 2" bb and 1" bumpstops. when ya get carried away with shock length without relocating the mounts, you need longer bumpstops to keep the shocks from bottoming out. the highlines are enough to run 35's on stock suspension with a 1" bl also. mine is on a 2.5" rancho, 2" bumpstops front and rear, 26" long rancho shocks, 34" trXus mt's. it's clearanced for 37's with DIY highline fenders. ![]() ![]()
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#9 |
my plan eventual plan: 2.5" OME, 1" BL, highline tube fenders + 35s for offroad, skinny AT 33s for winter.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#10 |
Well, i do think that RE makes the best spring on the market, but their is a lift issue... Coilovers are little pricey and i was trying to find something on, let's say, on a average buget...Still shoping around, not so sure yet.
Any toughts? |
#11 |
your suspension has a given amount of travel. As you set it up for increased down, you loose up. Unless you lift. this can be uncomfortable when hitting bumps and pot holes at speed.
RE does make nice stuff. But there are plenty of others that might be better. Are you going long arm or short arm?
Get Savvy |
#12 |
Understand this. Long arm, of course
#13 |
have you read Long Arm 101 yet?
Get Savvy |
#14 |
Another great text-))) Thanks
Another great text-))) Thanks.
Let's put it this way. In my mind, ideal combo looks like LCG (high rise etc.), 2-2.5" lift (springs), longer (26-28") shocks, long arms (at least lower), telescoping drive shsft. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
