#1 | |
AEM Intake observations
Today I yanked my AEM intake tube & filter off and replaced it with the stock intake.
WHY? After off-roading with it for one season, I've had to clean the filter twice....the dust clogs it up very quickly. Once clogged, the intake makes weird noises that sound "groaning", and it idles high. I also found the entire inside of the throttle body below and all around the blade was black with a thick oily carbon buildup. I think this is a result of the oil on the AEM filter. The inside of the tube was also lined with a very fine layer of dust. The fender would also pack thick with dirt, I even tried lining rubber under the filter and boxing it in. Rubber did keep mud and water from wheeling off the filter, but I still got dirt and dust caked on the rubber. So far, with a FRAM paper filter, the engine is more quiet (no more whistle), and the groan is gone. I also sprayed a throttle body cleaner in the TB pretty liberally, cleaning out the idle pass thru and the blade and below. Idles much smoother and throttles more smoothly. I may experiment with another stock intake if I can get one cheap, and cut the box apart and make a high flow tube out of the AEM tube & the stock filter box. Update: The TB spacer did nothing. I noticed no difference in power and colder intake temps with the stock intake.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 11-15-2007 at 08:58 PM.. |
#2 |
I found oily residue in my stock tb when I replaced with 62mm tb and spacer and that was after running stock box and paper filter. maybe oil was in there from assembly? either way i am aiming my sights towards a Volent air intake due to the fact that they use an inclosed air box and a snorkel can be added at a later date.
Power gains are noticable from bigger tb and spacer, not too much but it helped a lot with throttle control and low end torque. Please note that your intake under tb is only 60mm so in order to get full benfit from your set-up you may want to port the intake. this is My opinion however you may want to ask around.
-CHAPPY- |
#3 |
I was forced to mod my air intake when I did my tube fenders (cone filter over a hacksawed intake pipe. I dont have a sock over the filter yet but I am going to get one soon. I suggest that to anyone to help aid cleaning and eliminating some of the dust. Its not a perfect solution but Im in a situation now where I have no choice.
#4 | |
FireFighter's Jeep Club #84 I started out with nothing and still have most of it left. Im getting tired of thinking...guess I'll do some wishful drinking. |
#5 |
Guys, a pre- filter is a trumped up version of pany hose!! haha.
I use a new pair of (cut to fit) pantyhose to cover my dirt bike K&N when I go to the sand dunes, works great and it is way way cheaper. Just be prepared to get weird looks from wal-mart check out girl or send wife if so equipt. hahahaha
-CHAPPY- |
#6 |
OIL on an AEM? What did you do? All the new AEMS have no oil. Havent had to clean it in over a year. Also run an outerwears pre-filter. Sounds like you had a crappy old style one
2004 Khaki Rubicon. Jeeperman Custom Brushguard and 54" bumper, Kilby steering skid, Skidrow radiator skid, SRC Rockcrawler rocker guards, UFW Al Engine Skid, OME Shocks, JKS Quicker Discos, AEM Dryflo intake;KC Slimlight 130W Long range lights, ORO LiteDots and LitePlate, Banks Stainless Monster cat-back, Eclipse stereo, BA Speakers, Jeeperman Handles, Cobra CB, interior leds... more to come. **R.I.P NOW TOTALED** 98TJ Sport, 30x9.5 BFG ATKO's on AR Outlaw II's, K&N FIPK, Borla Catback, Green jeep club member #139 |
#7 | |
Demonic Jeep Freak!
#8 |
Pulled my AEM couple of months ago, stock intake is much quieter and I think the mid range torque is improved. I know the engine response is better and the intake system is clean!!!!
#9 |
I agree with the rest. Oil on an AEM? when did you buy this cause you got jacked. If you want a better filter buy the dry flow filter it works much better and doesn't get clogged as much.
00' jeep Rock Krawler 4" plus, Bilstine 5100's.
33" BFG KM2 on Craiger Soft 8's, A.A. SYE, Tom Wood Drive shaft, I wave. |
#10 | |
doesn't get clogged as much? I don't see how it could NOT get clogged. I've had several millimeters of dirt caked inside the fender well, right below the filter. It sucks all that dust and dirt into the filter when I'm off roading. The stock intake has the air inlet tucked up against the hood (better for water crossings, think mini-snorkel) and while the bottom of the stock box may get dirty, the inside stays nice and dry. After seeing how dirty the inside of the engine compartment gets, I don't see how you would want a wide open element inhaling from the middle of the storm.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#11 | |
Do it right or not at all
![]() Join Date: Jan 2003
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#12 | |
I'm not even certain I felt any difference when I installed my 63mm TB. ![]()
#13 | |
#14 | |
and for the second time...I HAD AN OLDER STYLE AEM INTAKE..WHICH NEEDED OIL.
#15 |
never had any problems w/ my AEM and i like them because you dont have to oil them. you can get a dust sock for them if you need also. i used the TBS because it comes with the kit. not sure of any benefit. i kinda got used to the diesel whistle noise after 3 years.
yellow jeep club #343 IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
