advice on a TJ project - JeepForum.com
post #1 of 23 Old 08-02-2010, 07:55 AM Thread Starter
TJe0454
im in the process of getting an 01 wrangler sport. its completely stock right now...but not for long haha. i plan on lifting it and putting on some 33" tires soon. what name would you recommend from the tires to wheels to suspension? this one is going to see some trails. (im aiming to get the best bang for the buck as im on a budget too)
also, what would you suggest for audio components (for the future)?
TJe0454 is offline
post #2 of 23 Old 08-02-2010, 07:59 AM Thread Starter
TJe0454
TJe0454 is offline
post #3 of 23 Old 08-02-2010, 08:04 AM
JeepDVL45
Back in the game
JeepDVL45's Avatar
As for tires, I have some Interco's M/Ts (31x10.5) and I love them. I have cragar wheels ($40 each). As for bang for your buck, they're probably the best way to go. I don't get to hit trails often, because my TJ is my DD, but my tires have ripped me out of some 'qustionable' situations.
You'll get a lot of debate about 'best lift'. My suggestion is to use the search function and research the crap out of every possibility and wait for a promo. I know that RC still offers 10% off Jeepforum members and you could get their 3.75" combo lift (2.5" suspension and 1.25" body...that will clear 33s for you and you shouldn't need a SYE or new drive shaft) I personally have a RE 2"BB and just picked up a RC 1.25" BL. Not quite enough to run 33"s but if I bumpstop correctly I should be fine
JeepDVL45
"Real men hide their feelings, WHY?!
BECAUSE IT’S NONE OF YOUR ****** BUSINESS!!!!
Men do not cry. Men do not pout. Men jack you in the ******* jaw and say…thanks for comin’ out." - Boondock Saints II
JeepDVL45 is offline
post #4 of 23 Old 08-02-2010, 08:57 AM
zachbh
Welcome to JF, I hope you can snag that TJ and start wheelin! What are the specs on it? I know you don't 'own' it yet, but filling in your profile would help us help you. I can't remember off the top of my head if all Sports have 44s or not... I think they do?
I recommend you do a lot of research here before buying anything, there is a ton of good information. Head over to the audio section of the forum for speaker recommendations. And if your planning on 33s, plan on an aftermarket rear bumper/tire carrier to support the extra weight.
zachbh is offline
post #5 of 23 Old 08-02-2010, 02:32 PM Thread Starter
TJe0454
thanks for everyones advice so far. all i know is that it has 3.07 axle ratio. will a 4" lift need any other alterations other than the actual suspension? im talking in terms of transmission, etc. im not a new to jeeps, i had a 00 sport for its whole life from factory to tree but i am new to mods.
-Thomas
TJe0454 is offline
post #6 of 23 Old 08-02-2010, 03:22 PM
Caribic-TJ
-Thomas
3.07 axle ratio and 33" tires is not a good combination.
Caribic-TJ is offline
post #7 of 23 Old 08-02-2010, 04:19 PM
alittleoff
It would be good to consider a few safety items also.
Fire ext., first aid kit, strap, a hi-lift jack and bolt in cage.
Enjoy round two.
Steve
alittleoff is offline
post #8 of 23 Old 08-02-2010, 04:29 PM
freeskier93
It's a 4.0, it will be fine. Not the best, but it will be work.
OP, if you have a d35 I don't suggest regearing, if you have a d44 and have some money to spend go 4.88s.
freeskier93 is offline
post #9 of 23 Old 08-02-2010, 05:09 PM
jdub36
I tried 3.07's and 33's, it was terrible. It was extremely hard to maintain speed and that thing sucked gas. If you are dead set on 33's and wheeling it hard i would look around for one that had a dana 44 in the rear it will save you a lot of head aches down the road. You might be able to run down an older rubicon i have seen some pretty good deals on some lately and they will go lots of places right out of the box. Just something to think about before you start a project.
jw
jdub36 is offline
post #10 of 23 Old 08-03-2010, 11:29 AM Thread Starter
TJe0454
so what do you all suggest? 3.73? 4.10?
TJe0454 is offline
post #11 of 23 Old 08-03-2010, 05:49 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What transmission?
Manual = 4:88 or 4:56
Automatic = 4:10
Knuckelhead is offline
post #12 of 23 Old 08-03-2010, 07:48 PM Thread Starter
TJe0454
5 speed. i heard of this shop called Appalachian Offroad Inc. its in westminster md. anyone have experience with them? im thinking of having them do the regearing.
TJe0454 is offline
post #13 of 23 Old 08-06-2010, 01:39 PM Thread Starter
TJe0454
so i got the jeep and im paying off it now. the tires have low tread so ill be replacing them within the year. i was thinking of going with a 2 inch body lift and 33" for now. any thoughts? i know that a 4" and regearing to 4.56 or 4.88 would be the ideal situation but im short on money for the time being.
thanks
TJe0454 is offline
post #14 of 23 Old 08-06-2010, 03:11 PM
Apocalypse
33s and just a 2in body lift isn't enough. Unless you extend the bump stops like crazy which will leave you with no flex and a crappy ride. As for budget I netted a little more than 3inches off my lift that consisted of 2.25 bb in rear, 3in BDS springs up front, and skyjacker hydros for shocks. The whole deal including some used quick discos for the front was less than $350. I can post a pic if you want to know the looks of a lift like that
Apocalypse is offline
post #15 of 23 Old 08-06-2010, 03:42 PM
thirdeye
If you are hoping to save up and do a 4" in the future I'd say don't Body Lift it... just do a BB for now instead.
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
audio , lift , suspension , tj
Need advice on project osmondmark YJ Wrangler Technical Forum 1 01-25-2010 06:16 PM
Project Weekend, Any Advice CheapJeep92 YJ Wrangler Technical Forum 11 07-05-2007 11:47 AM
87 project, just starting and need advice. MuddyMules YJ Wrangler Technical Forum 7 11-13-2004 06:32 PM
ARB Lighting Project, Need Advice WR4NGLER TJ Wrangler Technical Forum 1 09-05-2004 11:25 PM
