Advice on tire size increase please
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
OK, I used the search function for an hour+ or so and it did not completely answer the question I have...
Got the Wrangler last month. Love it, but it needs bigger tires. It now has 215-75-15 on 15 x 8 wheels (yes a very goofy looking combination). I believe the 1st owner got bigger wheels first and before getting bigger tires for those, he sold it, so the tire / wheel upgrade was only half done. Jeep is a 2006 Wrangler X, 4.0 liter 6 speed manual with 3.07 gearing. I will use it 85% on 2 lane country roads at 60 to 65 MPH with some hills. Off-roading will be mostly dirt ranch roads, pastures, gravel / dirt trails. No extreme trails. I want to go to 30" or 31" AT tires like a General Grabber AT2. The current 215's are 27.5" in diameter. So I would be going up to 29.5" or 30.5". I dont want to it to become a dog because of the 3.07 gears with too big of a tire diameter. I probably will never regear it. If I lift it, it would only be a 2" BB. I'm guessing I will be happier with the performance/ power the 30" tires will offer vs. 31". Would really like comments from those of you with the 4.0, 3.07, six speed setup as to what tire size works well. Also to re-gear the speedometer on an 06, is it electronic or a speedo gear change? Thanks.
06 Solar Yellow TJ X obtained 10-2009 with 3400 miles 99 Cherokee Sport, bought new, now @ 223,000 miles Southwest Texas |
#2 |
TITS
Go 31's. Your 6 speed will help take up some of the suckiness of 3.07s due to it's lower gearing. And I thought I would never regear or go any larger than 31's either.....
#3 |
The 3.07's are going to cause you to use the gearbox more regardless so I say 31's over the 30's, Both you will have the same performance challenges but the 31's will look better. Have fun.
Bill J. |
#4 |
I ran 31's with 3.07's and it was OK .. you'll use 4th a bit more on hills.
I found with 31's my speedo was spot on as well (GPS verified) .. it was off before.
---------------------- Formally 88Jeepster ---------------------- Who's in front ? Ridin' topless again .. sweet !! |
#5 |
TITS
The OP has the NSG370 6 speed, not the NV3550. Due to the low first gear and low OD (6th), the 3.07's will be more livable than with any other transmission Jeep used.
#6 |
Demonic Jeep Freak!
Go with 31's or you'll regret it.
#7 |
Demonic Jeep Freak!
#8 |
Never thought I'd see you say that!
“This isn’t the Old West, because the New West has never arrived. It’s just the West, like Wyatt Earp died yesterday.” ─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996. |
#9 |
Demonic Jeep Freak!
#10 | |
See Ya Coach.
#11 |
had question about post 5, but then realized #2 was same author and that answered it.
As it is now, I often shift 1 to 3, skipping second because 1 & 2 are so low, you dont build up much speed in second. Maybe 31's will make 1 & 2 taller and not make first such a granny gear.
06 Solar Yellow TJ X obtained 10-2009 with 3400 miles 99 Cherokee Sport, bought new, now @ 223,000 miles Southwest Texas Last edited by twobit; 11-12-2009 at 01:13 PM.. |
#12 |
Demonic Jeep Freak!
#13 | |
Demonic Jeep Freak!
#14 |
Yeah, I put 31x10.5's on my stock '05 TJ and it looks superb. I'm rolling on 15x7's but I don't imagine that will make too big of a difference. The 31's just make the Jeep look like it's supposed to stock. Anything less will be disappointing. Also, I second the starting off in 2nd gear from the above poster.
#15 | |
See Ya Coach.
To the OP....go with 31's. You will be alot happier in the long run. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
