Advice on RCD Suspension 3" Lift Kit with Bilstein Shocks - JeepForum.com
post #1 of 13 Old 07-20-2010, 06:39 AM Thread Starter
stevefarling
From Quadratec.
What do you think of this kit?
RCD Suspension 3" Lift Kit with Bilstein Shocks for 97-06 Jeep® Wrangler TJ & Unlimited - Quadratec
stevefarling is offline
post #2 of 13 Old 07-31-2010, 10:57 AM
sluggermyers
yeah i'm wondering the same thing
sluggermyers is offline
post #3 of 13 Old 07-31-2010, 11:56 AM
paydirtdave
Just installed the RCD 4" lift and all went good, the directions where a bit confusing at times. The parts packaging was neat and user friendly. The control arms, sway bar links and rear track bar relocation bracket are textured powder coated. I was able to do coil spring installation without spring compressors. I do have a drive line vibration that I am deciding on how to deal with and have not yet dropped my transfer case. If anyone can tell me how to post pictures without being a full subscriber I would be happy to. I am a backyard mechanic and new to the lifted jeep craze but would be happy to answer any questions about my RCD 4" installation.
paydirtdave is offline
post #4 of 13 Old 07-31-2010, 12:15 PM
glockster
Once you get to about 25 posts you'll be able to post pictures. Keeps the spammers at bay as they can't spread there BS the day they sign up.
Marco
glockster is offline
post #5 of 13 Old 07-31-2010, 12:51 PM Thread Starter
stevefarling
Thanks paydirtdave! Tell me, other than the vibration, how's the ride? Also what size, and brand tires are you running? I haven't decided on a 3" or 4" kit yet, but either way I won't be doing it till spring. It just looks like a quality kit to me. Did you make any other changes or add ons with this install?
post #6 of 13 Old 07-31-2010, 03:40 PM
paydirtdave
I went with the RCD 4" kit because the 3" kit is or was on back order---easy enough. The ride is stiff and crisp, smooth on the road and very ridged on the back roads. My vibration came at about 45-mph so over all little driving has been done. Front of jeep sits a bit higher than the back but should level off. I am running Goodyear MTR 245/75/16 but will be getting 33" and keeping the stock Moabs once I take care of vibration, alinement and re-torque everything.
No other add ons other than cosmetic but (The Dog Must Eat)
The only thing I might have done differently would have been to get a $3000.00 long arm kit and about 10 grand in other goodies and go real BIG but I went with what fits my budget and lifestyle.
I will post more about my experience with the RCD 4" lift as I put Rubber to Road
post #7 of 13 Old 08-04-2010, 06:00 PM Thread Starter
stevefarling
Cool! Thanks Dave!
post #8 of 13 Old 08-05-2010, 11:15 AM
paydirtdave
Ok I have learned a bit over the last few days and wanted to share it with you all. First off I am new to the lifted jeep craze and am by no means a expert. With that being said the budget lift kits are a bit deceiving. I went with the 4" RCD lift, so I don't know if this holds true for smaller lift kits. The directions and advertisement are a bit misleading, leaving the jeep owned feeling all he or she need to do is install the kit have the jeep alined and run your larger tires. Not the case for me and my RCD 4" kit. As it turns out I am now into it another $1130.00 on top of the cost of the kit. After talking with some real nice people on this forum we put together a list of my options that would cure my new drive line vibration caused by the lift. What I have bought aside from the RCD kit is a Tom Wood's double cardan drive shaft $330.00 and a set of Curries upper and lower front and rear adjustable control arms $800.00 This will allow me to run my transfer case at the stock hight and be able to adjust my caster and pinion angle. There are other ways to fix the drive line issues by using just upper control arms and or motor mount lift's along with transfer case lowering spacers. I decided to ask the advice of others and spend the cash and do it right from this point forward. If I could do it again I would find a complete non budget kit and figure on spending a bit more. I would like to thank all who have supplied me with sound advice and have walked me through the steps needed to get things right.
Thanks All
post #9 of 13 Old 07-29-2011, 04:27 PM
marker
4' rcd
I'm looking at putting the same lift on my Rubicon. Did you need extended brake lines or anything else for the lift. I know I need the double cardan shaft, but other than that and adjustable rear uppers, do I need anything else? I am also trying to decide if I should do the 3" RCD and a 1" body lift that might spare me from needing the drive shaft. I am very new to the whole lift thing so I am very confused. I get conflicting stories from people and the online chat guy on Quadratec was not very helpful at all. Thanks for any advice. I got told by the quadratec guy that I would need extended brake lines, but never hear anyone else saying they used them.
marker is offline
post #10 of 13 Old 10-10-2011, 08:46 PM
GOLD1999TJ
I just recently installed the 3" RCD Suspension and it was well worth it. The ride Quality is excellant and the handling with my coopers was good. The 2 extra items i purchased as well as the lift was the JKS adjustiable track bar, an OME steering stabilizer, and a 37 tooth speedo gear (if you run larger tires, a 37 tooth is good for 31 and 32 inch tall tires). the install was fairly easy, my father helped me with mine and you will need a few extra things. i recomend a second pair of hands, coil spring compressers, a good torque wrench, and a haynes jeep repair and maintinance manual. all in all it is an excllant lift. you will not need extended brake lines.
GOLD1999TJ is offline
post #11 of 13 Old 05-13-2016, 10:56 AM
EricD
I'm looking at this lift. Last post was 2011. Anyone have any updates on this lift kit and reviews or recommendations?
EricD is offline
post #12 of 13 Old 05-13-2016, 11:39 AM
joe_jeep
if it was not posted about it since 2011, there might be a reason?
for cheap stuff look at zone or bds.
for top notch stuff look at currie and savvy
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #13 of 13 Old 05-13-2016, 02:42 PM
EricD
Well, I didn't necessarily think it was a cheap kit. From what I understand, Bilstein shocks are really good, and RCD, I think has good reputation. I was just looking for possibly someone that had some first-hand experience.
EricD is offline
RCD , suspension , kit , bilstein , lift , tj , wrangler
Bilstein or OME shocks with 2.5 lift drespecki YJ Wrangler Technical Forum 4 06-18-2010 10:08 PM
What should I get question! Oh no! Want advice shocks & suspension for low COG build. guht TJ Wrangler Technical Forum 3 05-21-2010 09:01 AM
5.5" lift & Bilstein Shocks? boozewell TJ Wrangler Technical Forum 2 05-14-2010 07:54 PM
Quick Question (Bilstein shocks w/ RC LA lift) Welke TJ Wrangler Technical Forum 4 01-14-2010 04:07 AM
TJ 4" Lift...Bilstein Shocks beachboy1200 TJ Wrangler Technical Forum 8 02-26-2009 09:59 PM
