Advice needed on which 1” body lift.
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
I’m going to add a one inch body lit to help with clearance of the 241OR transfer case and home made belly up slid plate I have been working on. Is there any brand that is better than other?
I can see there are 2 choices really. One a hard block type lift like this. http://www.4wd.com/productdetails.aspx?partID=10226 http://www.4wd.com/productdetails.aspx?partID=6751 And the other a poly kind like this.. I just wondered what the pro’s and con’s are for each kind. Thanks Dave
#2 |
Demonic Jeep Freak!
Performance Accesssories is a complete kit.
#3 |
#4 |
ive got a JKS 1.25" BL. works great and looks stock.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#5 |
I've overwhelmingly ben told the JKS BL is tough to beat, it is a spacer lift that keeps your factory rubber mounts in place. Some don't like the "look" of the spacer type lift saying it is not as "clean" looking I guess, but all in all it has great reviews and great support. I'm getting one this month along with there MML.
Owning a Jeep makes a heroin addiction look like a vague yearn for something salty... 2002 Inline 6 TJ-X 4.0, D30/D35 w.4:56s 2inch BDS Full Coil Suspension, Incubus 511 Rims, 33inch Mickey Thompson ATZ, Bestop HighRock Front (w/Stainless Grill Guard) and Rear Bumper, KC SlimLites, Custom "TJ" Tail Light Covers When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of! : ) |
#6 |
Demonic Jeep Freak!
#7 |
The jks 1.25'' is a clean looking kit when its on the jeep. The poly lift blocks have a flange that hangs down over the original bushing and makes it look seamless.
#9 | |
the JKS and the PA are using a spacer that is added to the existing bushing and the energy one is a all new set of bushings that happen to be one in higher? Thanks Dave |
#10 |
Demonic Jeep Freak!
A BL is a BL unless you get a 3" one.
#11 |
To my understanding, this is correct. I think the energy ends up being alot more expensive and I dont know if you get a t-case lever correction bracket with the kit?
However, if you are doing a belly up at the same time then you wont need the t-case drop down bracket anyways. It is a possibility that you will need a bracket like the one advance adapters, skyjacker, or novak(this would be my choice) makes that makes the t-case lever operate independent from the body tub. The jks is a complete kit with everything you need, hardware, brackets, ect. |
#12 | ||
RESIDENT METAL
I have a Jeep. Quote: Quote:
#13 | |
I am not worried about the shifter linkage as with the belly up its so high right now its hitting the tub, if anything this may give me the room i need under there. Thanks for the info.. Dave Last edited by tooofast; 12-22-2008 at 11:58 AM.. |
#14 |
...the JKS lilft also comes with new rubber nubs for the grille!
2001 Anniversary Edition Wrangler 2.5" OME HD Lift on ProComp M/T 32"s. Aussie Locker in front. Skid Row armor & fresh radiator fluid. XM Satellite Radio - SKYFi2 and some cosmetic mods. |
#15 | ||
RESIDENT METAL
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
