#61 | |
tonight I removed the old gas tank. I really dislike those gas connections. out of 5, all came apart in my hands except 2. you would think they could make these little clasps out of a plastic that doesnt get brittle with age
. also the new tank straps dont seem to reach with the new tank. looks like a trip to the dealer tomorrow for another unplanned expense. While i am there I will pick up a set of exhaust manifold gaskets and new bolts.
[COLOR=Navy][SIZE=2]03 Patriot Blue Sport[/SIZE][/COLOR] Rubi d44 both ends, Crane Diff Covers, Rock trac t-case Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers knoblock rear bumper, OBA in process, bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax Currie HD steering Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt HEMI & 5spd Auto |
#62 |
Subscribed.
I always wanted to say... "yea, its got a hemi." |
#63 |
man, i've been waiting for this so long every since you got the donor...sorry the unplanned expenses are occuring, i know how it is
02 TJ with scratches
www.handegraphix.com |
#64 |
I agree I would love to say "Yeah i got a hemi"
00' jeep Rock Krawler 4" plus, Bilstine 5100's.
33" BFG KM2 on Craiger Soft 8's, A.A. SYE, Tom Wood Drive shaft, I wave. |
#65 |
Fish fear me
Why does the gas tank have to swap?
2003 Lt. Khaki Rubicon automatic Supercharged 4.7 stroker w/ Hesco aluminum head 70mm F&B throttle body Kieth Black forged 944 pistons Comp Cams custom ground camshaft 505 Performance PCM Split Second Engineering fuel/timing management Tom Woods CV driveshaft 50 lb/hr Trick Flow injectors 4" Full Traction LA with Bilstein 7100's JKS 1" MM,BL. TeraFlex engine and steering armor 4.88's w/ 35 " Toyo Open Country m/t's Moser Chromoly axle shafts front, Superior D44 rear Warn 9.5ti on a M.O.R.E hi clearance bumper Reid racing knuckles, Warn premium hubs PIAA 525's, and 510's XBOX Gamertag- ISHAGDyurGURL For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30 |
#66 | |
if you look at the two tanks the pump and lines are completely different. the 03 uses a different fuel/vapor system than the Ram 1500 5.7L computer donor uses. It just so happens that DC changed the wrangler to the same fuel/vapor system as the Ram in 05.
#67 |
bringing this one to the top for updates...
#68 |
sorry...OT all week and Xmas party tomorrow. I will get back on it saturday..
the plan, pull clutch pedal, pull dash, replace harness, maybe set motor in and tack mounts... the difficulty will be that I dont want to do the recommended 1" body lift so I am debating redrilling the motor mount down a half inch, hatcheting the hood or massaging the tunnel to fit. I have to see how it all shakes out....
#69 | ||
Never Forget
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
#70 |
Just violated my Parole
which would be a plus for a jeep.
do you have a D60 planned for the rear end? |
#71 |
HOLY SH$T! This is the first time I have read this post. I was nervous about my SYE install until I read this. Now I can do anything!
#72 | |
i will go bigger if I break the d44 with alloy usa axles. the nth limits my choices on the rear. my first choice would be a currie built high pinion 9" with an arb. I may still do it, but I will hold off until the d44 lets go.... they are making a stinger for the rockjock or one of those special d60's I dont know. but if I do it I want the high pinion for my trouble...
#73 |
Nth came out with a HP60 Stinger. There is an article in the Jan edition of 4 Wheeler Magazine. I think it is called "A killer stinger, for a Killer Bee." (or something along those lines)
I am having a custom built HP60 put in early next month. The shop is probably going to have to fab something to make it fit------ but they said that they can make it work. But I think you should be fine with the 44, considering that the SRT-8 6.1L comes with a 44 in the rear. I doubt that your going to be hammering the hell out of it off road (or will you? ). If not, you would probably be fine for a good while..... especially w/ the chromoly shafts.
[SIZE="1"][COLOR="Blue"]Nicholas[/COLOR][/SIZE] ------- [COLOR="Blue"]Lock'd, Rock'd, but not ready to roll. [/COLOR] [SIZE="2"]There needs to be a Twelve Step program to stop the modding addiction![/SIZE] [SIZE="4"][B][COLOR="DarkRed"][U]SAVE PARAGON![/U][/COLOR][/B][/SIZE] Visit [url]www.saveparagonap.com[/url] to get more information. |
#74 |
dude, u are awesome and so will the jeep b too!
6/5/2011 back in a jeep. 4 door jeep wrangler, green,soft top, 6 speed transmission |
#75 |
can anyone give me a part number for this little plastic clip? it goes on the fitting for the line to pump and the fitting for lines from the tank to the lines down the driver side frame rail over the rear end. the the dealership parts guys cant seem to look anything up for me. Otherwise I am just going to thread a zip tie through where this clip went. all it does is keep the gas fitting together by filling a gap. the lines do all the seal function. anyway, I need to get 4 of these little clips to put the new tank in....
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
