Advantages of front and rear adjustable trac bars ? - JeepForum.com
post #1 of 5 Old 12-05-2004, 03:13 PM Thread Starter
Humberto Benavides
Humberto Benavides's Avatar
Do I get any advantage with front and rear adjustable trac bars ? I installed a front one when installed my RE 3.5 SF and now I'm waiting for the rear one to arrive home. Do I suppose to uninstall the rear tracbar bracket provided with the RE 3.5 SF and install the adjustable rear one, or do I need to leave the bracket in place and install the adjustable tracbar. If so, what's the advantage of have a rear adjustable trac bar ? I know one of the advantages of have the front one is that I doen't needed to drill an additional hole in my front tracbar mounting bracket, but what about the rear one ? I'm confused !
'03 Jeep Wrangler X Auto I6 4.0L, 3.5" RE Super Flex, 1" PA BL, M.O.R.E. 1" MML, 33x12.5x15 MT/R's, JKS Quick Discos, RE Front Adjustable Trackbar, Skyjacker Hydro7000 Shocks, OEM RUBICON Rocker Guards, WARN Steering Skidplate, Front Mopar Tow Hooks, Bushwacker 6" Extended Fender Flares, K&N drop-in air filter, Chicago Electric Winch, SS light bar with 4 Hella 500 Driving Lights, and stock no more !
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
Humberto Benavides is offline
post #2 of 5 Old 12-05-2004, 04:54 PM
btolle
The advantage is you can center the axles. The brackets are a "one size fits all" deal that may or may not center your particular axle.
You don't use the bracket with the rear adjustable track bar, it goes into the original mounting bracket on the axle.
Bill Tolle
04 Sahara
04 Liberty
04 Kubota B7510 4WD w/Manual Locking Rear Differential and Front End Loader
If you love offroading and want the trails to stay open please join Blueribbon Coalition.
"Preserving our natural resources FOR the public instead of FROM the public"
http://www.sharetrails.org/
btolle is offline
post #3 of 5 Old 12-05-2004, 05:46 PM
jasonh
Not to cause and argument here but...
I would use the track bar bracket with your new adjustable track bar. You will get a greater amout of droop out the the left rear with it installed. You may get binding problems without the bracket because the track bar will be at a greater angle and the origonal mounting location is boxed and the track bar will strike the top of the bracket. Your RE bracket is open on top so there is nothing to bind up on. RE even makes a tilted bracket if you are running a steep pinion angle with a larger lift so the track bar is not forced to twist when the suspension cycles.
Jason
97' TJ Sport
  • 4.0L, 5 Speed, Tera 4:1 & 2 Low, RE 4.5" Super-Flex, 34" Trxus MT's, 4.56 Gears, ARB's Front and Rear, HS9500 - when all else fails + Lots of other stuff...
jasonh is offline
post #4 of 5 Old 12-05-2004, 05:54 PM
kpatrick
Bill Tolle
04 Sahara
04 Liberty
No, that's not correct. Use the trackbar relocating bracket that came with your lift with use of an adjustable track bar.
3rd time around with 2006 2.4L 6sp, warn bumpers front/rear, clean slate to work with-need ideas....
kpatrick is offline
post #5 of 5 Old 12-05-2004, 09:35 PM Thread Starter
Humberto Benavides
Wow, great to learn from all of you !!!!!! I'll use the trackbar bracket for sure, 2 vs 1 tells me that I need to use the provided bracket, so I'll install my new adjustable RE trackbar with the RE trackbar bracket for sure ! Thanks to all !
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 09:01 AM
Front and Rear trac bars question Fredo TJ Wrangler Technical Forum 1 06-15-2009 07:50 PM
Front and rear Trac bars on SOA madjeep1 YJ Wrangler Technical Forum 8 06-05-2009 10:35 AM
Need front and rear trac bars? Knot TJ Wrangler Technical Forum 7 11-05-2008 09:47 AM
Adjustable Trac Bars No Fear Jeep TJ Wrangler Technical Forum 2 07-12-2007 06:49 PM
