Advance Adapters or Skyjacker transfer case bracket?
| Front and rear Drive shafts @ free shipping | Poison Spyder February Special: FREE Rubber Liners when yo | Slappin' on 61,510 Rigid Industries Lumens for Big Red |
#1 | |
I am looking to move the transfer case shift bracket off the body and found two differant relocation brackets that do just that. The Advance Adapter ($33) and the Skyjacker ($80). Which is the better product, money isn't a concern but why waste $50 if I don't need to.
http://eshop.advanceadapters.com/commerce/ccp1461-stand-alone-tj-26-cherokee-shifter-bracket-715542-715542.htm http://www.skyjacker.com/products/products_search/number_detail/?f_part_number=jsrb231a
#2 |
They are the Same thing...Either one...:P
#3 |
But they look (almost) completely differant?
#4 |
I have the SkyJacker one....
#5 |
So if they are "the same thing" why did you buy the skyjacker one?
#6 | |
#7 | |
damn good reason right there
![]() what are the reviews like one these brackets, I have heard some good things through the grapevine but want to hear it from someone personally.
Low Output 4 Cylinder Jeep Club #420 Quote:
#8 |
Got link for that one?
#9 |
Im using the AA bracket no complaint, way better than stock, nice and smooth shifting and no more binding.
1997 TJ SPORT MANUAL | 4.0 L | HD O.M.E. | 31" BFG | 15x8 AR STIC | P.A. 1" BL | M.O.R.E. 1" MML | AA sye + TW | JKS uca | JKS lca | JKS t-bar|JKS disco| Bob Supplee:supplee4wd@sbcglobal.net or (405) 799-8977 www.northridge4x4.com |
#10 |
I couldn't find the installation pdf on AA's website for their TC bracket. The picture they show is also a new design and I can't see how it works. I googled it and found install pictures of the OLD design but nothing on the new design. Anyone have a current pic of the new designed AA bracket installed?
The Skyjacker is advertised at Quadratec as "hard install" with "cutting and welding required". I don't believe that's true though. |
#11 |
Locked @ both ends
The best one is from novak conversions. By far the best ouyt there. i have used the skyjacker and a buddy of mine had the AA. Both work just fine but this is what you should get. After i changed over, I could not believe how easy the tcase shifted.
http://www.novak-adapt.com/catalog/kit_sk2x.htm |
#12 | |
[SIZE="1"][COLOR="SeaGreen"]2005 Grand Cherokee Rocky Mountain ed.[/COLOR][/SIZE] [COLOR="Navy"][SIZE="1"]2006 Jeep Wrangler X 4” lift, 35X12.50R-15 BFGoodrich Mud-Terrain T/A KM2, 15x8 Ultra Baja Champ BLK MA LP, Fabtech Steering Skid, Skid Row Radiator Skid, RE Extended Brake Lines, RE Steering Stabilizer, JKS Discos, JKS ADJ Control Arms, JKS ADJ Trackbars, AtoZ Fabrication Rocker Guards. Trail-Gear Rear Tire Carrier, Superwinch LP8500, D44, Currie HD Tie Rod System, AA SYE and CV Driveshaft. ARB Snorkel. Riddler D44 diff Cover, Solid D30 Diff Cover, Novak TC Shifter.[/SIZE][/COLOR] |
#13 | |
#14 |
I have the AA bracket, didn't know there is a new version.
![]() ![]() ![]() Last edited by chuckv68; 02-12-2008 at 07:21 PM.. |
#15 |
Put the AA on mine after the tummy tuck. Solved the problems and kept money in my pockets for the atlas conversion coming soo
My 1 ton TJ build project "Evil Monkey": [url]http://www.jeepforum.com/forum/showthread.php?t=423989[/url] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
