#1 | |
Adjustments to Rear Control Arm
How much do I need to lengthen my upper control arms after installing a RE 3.5"
super-flex lift. Trying to correct angle on my rear pinion. 1999 TJ
#2 |
You'll need to get a magnetic angle finder and see what the pinion angle is and adjust from there. Every jeep's different so no one can tell you how much to adjust.
2001 TJ Sport: 4.0L, NV3550, D30/D44, 35x12.50x15 Maxxis Trepadors on DC-1s, 4.56 gears, Cromoly shafts & ARBs F/R, Full Traction 3" Lift, 1.25" JKS BL, Jeeperman Tire-Carrier Rear Bumper, Jeeperman Receiver/Winch Front Bumper, B&M Shifter, Kilby Gastank Skid, TBT Steering Skid, Nth° OPS, TBT Rock Steps, SkidRow Radiator skid,, IPF H4 (Fatboys), KC 100W Driving SlimLites. |
#3 |
How much are those?
#4 |
I don't know if they can be adjusted on the vehicle or if they must be set before installation, that is why I was curious about if there was a starting point.
#5 |
You can pick them up for around $220
#6 |
What are the tollerences, is there anywhere I can reference to get the proper angle?
#7 | |
See THIS and THIS
[SIZE="7"][SIZE="7"][SIZE="5"][URL="http://www.atozfabrication.com/catalog/"][B][CENTER][SIZE="5"][COLOR="Red"]AtoZ F[/COLOR][COLOR="White"]abric[/COLOR][COLOR="Blue"]ation [/COLOR][/SIZE][/CENTER] [CENTER][B][/SIZE] [SIZE="4"][/URL][/B][COLOR="Red"][/SIZE][/SIZE][SIZE="3"][URL="http://www.stickylee.com/catalog/index.php"]www.stickylee.com[/URL][/COLOR][/SIZE][/B][/CENTER][/SIZE] |
#8 | |
#9 |
Angle Finder: $10
Nth Degree rear upper control arms: $150 or so. The Nth degree RUCAs can be adjusted after installation. Install them at the stock length and adjust from there. I just did mine and it was a piece of cake. |
#10 |
Thank You!
I think it should go smoothly "I HOPE" |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
