adjusting track bar - JeepForum.com
post #1 of 10 Old 09-23-2008, 08:24 AM Thread Starter
Conti31
1997 XJ Cherokee
adjusting track bar
I have 3 rusty coils in the front with a 1.75 in spacer. Im ordering an adjustable track bar from rustys also and was looking for any tips on installation and adjustment settings. thanks in advance
Conti31 is offline
post #2 of 10 Old 09-23-2008, 08:48 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Install it with the wheels on the ground.
1. Unbolt the old track bar.
2. Drive the Jeep back and forth 20 feet or so a few times. Turn the wheel back and forth a little bit while doing this.
3. Park the Jeep with the tires pointing straight forward.
4. Bounce the suspension a few times.
5. Measure the tires and confirm the axle is centered. It should have pretty much self-centered itself.
6. If the axle is not centered, turn the steering wheel a little and watch how the body shifts over the axle. Estimate how much shift you need to get the axle centered and leave the steering wheel there.
7. Hold the new track bar up to the mounting points and adjust it to that length.
8. Bolt in the track bar.
9. Measure and confirm you have the axle centered. Remember that if you need to adjust for it being off, shorten or lengthen the trackbar about 1/2 the amount it is off since it adds to one side and takes away from the other at the same time. Use the method above (turning steering wheel) to move the body over the axle after you adjust the trackbar. Turn the wheel until the holes line back up so you can bolt it up.
10. Adjust drag link to recenter steering wheel.
The mistake most people make is trying to move the axle under the Jeep. Its much easier to move the body of the Jeep over the axle. If you have a helper, you can even have them just push on the side of the body rather than using the steering wheel to move it.
Wheelin98TJ is offline
post #3 of 10 Old 09-23-2008, 10:33 AM Thread Starter
Conti31
1997 XJ Cherokee
thanks bro
Conti31 is offline
post #4 of 10 Old 07-26-2009, 02:55 AM
robcabico
These are the best instructions yet. Thanks!
robcabico is offline
post #5 of 10 Old 07-26-2009, 03:00 AM
mudb8
want it rite or rite now?
mudb8's Avatar
5/8" longer than stock is a good starting point.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #6 of 10 Old 07-26-2009, 03:53 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Between you and Jerry B.I don't think anyone else's opinion's are needed.You guy's have the facts.
P.S. I could have used advise from both of you guys before I did the deed on my entire shoulder to arm tatt.
TheBoogieman is offline
post #7 of 10 Old 06-01-2010, 10:57 PM
autoposer
Hello all, I recently put an adjustable JKS trackbar on my 2000 XJ with a 3.5" lift. I thought I did everything correctly, but when I was finished my steering wheel was ~90 degrees out of phase with the wheels pointing straight. This surprised me. Did I screw something up or is this expected? I did have to ratchet the chassis over a good 2" to get it centered over the axle.
autoposer is offline
post #8 of 10 Old 06-02-2010, 02:19 AM
2006_Sport
Just adjust your drag link. Unscrew the 2 nuts on there and rotate the sleeve until the wheel is straight.
2006_Sport is offline
post #9 of 10 Old 06-02-2010, 02:26 AM
Imped
Imped's Avatar
Besides the fact that this thread is old and you're in the wrong forum, oh well. Your steering wheel is not the only thing off. The entire reason it's off is because your toe is off as well. Reset toe, center steering wheel, be happy. And let this thread fall back into cyberspace.
OlllllllO
IndyORV
Imped is online now
post #10 of 10 Old 06-02-2010, 11:38 PM
autoposer
Right, wrong forum. Damn I'm green... Thanks anyways, thats what I needed.
adjusting track bars grnsporty TJ Wrangler Technical Forum 3 02-17-2009 11:25 PM
adjusting adjustable track bar? drew76924 TJ Wrangler Technical Forum 7 01-25-2008 11:06 PM
Adjusting track bar... el guapo TJ Wrangler Technical Forum 4 04-23-2007 01:26 PM
OME lift-adjusting the front track bar mic6 TJ Wrangler Technical Forum 3 07-04-2005 09:55 PM
Adjusting the Front Track Bar TJBrowder TJ Wrangler Technical Forum 5 07-31-2002 10:53 PM
