Adjusting Pinion Angle - JeepForum.com
post #1 of 8 Old 10-10-2007, 04:09 PM Thread Starter
TJ driver
After my 2 inch lift my pinion angle is off which caused vibes and I had to do a TC drop. Is there any way to adjust the stock control arms or modify thier brackets such as slot thier holes and put some adjustable limiter on the bolts so that they are adjustable? I wouldn't mind getting adjustable rear upper control arms if they were under $200.
98 4.0 L TJ (DD)
TJ driver is offline
post #2 of 8 Old 10-10-2007, 04:18 PM
triola
Adjustable upper control arms are the only way to go IMO.
That was how I did it. However, I went with the Teraflex arms, back in 98. I would highly recommend you get any other brand, but not Teraflex.
98 TJ SE
Completely Line-Xed
triola is offline
post #3 of 8 Old 10-10-2007, 04:18 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your pinion angle isn't off enough to worry about with only a 2" lift. And the pinion angle is pretty fussy, don't mess with it unless you know what you are doing. Are you having vibes? If so, you can drop the t-case a half-inch or so, which reduces the angle at the driveshaft u-joint, to get rid of them.
Gone wheeling Friday through Sunday.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 8 Old 10-12-2007, 10:29 AM Thread Starter
TJ driver
I did do a 5/8" drop but why should I have driveshaft vibes with a 2" lift?
98 4.0 L TJ (DD)
post #5 of 8 Old 10-12-2007, 10:33 AM
Jerry Bransford
Administrator
Some TJs do fine with a 2" suspension lift and have no vibes at all, mine had no vibes when it had a 2" suspension lift. Other TJs get vibes with the same 2" amount of lift, not sure why. The old "it's a Jeep thing" saying seems appropriate in the 2" lift some TJs have vibes/some TJs don't have vibes thing.
Getting
post #6 of 8 Old 10-12-2007, 11:55 AM
cj847
Probably because you have an automatic. I had some serious vibes with my 2" lift. I have noticed on the board when people have vibes on short lifts many are coincidently running automatics. I don't know why unless maybe the auto is a few inches longer than the standards.
I went the MML route instead of dropping the tcase.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #7 of 8 Old 10-12-2007, 01:26 PM
waynehartwig
www.jeeperman.com
waynehartwig's Avatar
1946 CJ2A
You shouldn't get any vibes under 3" of lift. Try replacing your u joints with some quality Spicer ones, that should fix it - without the TC drop!
U joints that wear at a certain ride height and then have an increased ride height will wear in a different place in the joint, causing the vibration.
Try pulling front/rear drivelines seperately to determine which one is giving you problems. While you do this, you can check your u joints. The should move freely and not bind or have any resistance to 'flex'.
1946 CJ2A Ultra4 Race car, street legal!
waynehartwig is offline
post #8 of 8 Old 10-12-2007, 02:00 PM
rubicon35
they do make cam bolts to help adjust the pinion angle as well
rubicon35 is offline
Adjusting Pinion Angle. Canfourjeep TJ Wrangler Technical Forum 2 08-13-2009 06:13 PM
adjusting pinion angle jeep jake TJ Wrangler Technical Forum 4 03-05-2008 07:44 AM
Adjusting Pinion angle Benderff TJ Wrangler Technical Forum 2 09-09-2007 12:05 AM
Adjusting pinion angle... SYE kaffeene YJ Wrangler Technical Forum 2 05-10-2005 03:16 PM
Adjusting your pinion angle? ForkLift TJ Wrangler Technical Forum 12 02-18-2004 08:23 AM
