Adjusting the bands on a 3 speed auto trans - JeepForum.com
post #1 of 17 Old 11-17-2007, 06:43 AM Thread Starter
Erin Go Bragh
Erin Go Bragh's Avatar
I'm going to change my trans fluid and filter and want to adjust the bands while I'm in there. Anyone have a good link they can post up on how to do it properly ? I tried search and didn't find much. 2001 TJ 3 speed automatic. Thanks
"Some days I feel about as sharp as a butter knife."
"It's not the years, it's the mileage. "
"Common sense will take a person far in life, problem is, common sense just isn't very common anymore."
Erin Go Bragh is offline
post #2 of 17 Old 11-17-2007, 06:46 AM
binski
binski's Avatar
There was an easy tutorial even in the Haynes manual, but if I recall, the tricky part was having the correct in-lbs torque wrench. I'll try to find my older Haynes manual later and post up. Same procedure I used on my older '97 TJ
Binski
Binski
Christian Jeep Club Member 257
Red Jeep Club Member 245
binski is offline
post #3 of 17 Old 11-18-2007, 08:13 AM Thread Starter
Erin Go Bragh
Bump to top
Anyone ?
post #4 of 17 Old 11-18-2007, 11:15 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
From the FSM:
FRONT BAND ADJUSTMENT
The front (kickdown) band adjusting screw is
located on the left side of the transmission case
above the manual valve and throttle valve levers.
(1) Raise vehicle.
(2) Loosen band adjusting screw locknut (Fig. 179).
Then back locknut off 3-5 turns. Be sure adjusting
screw turns freely in case. Apply lubricant to screw
threads if necessary.
(3) Tighten band adjusting screw to 8 Nm (72 in.
lbs.) torque with Inch Pound Torque Wrench
C-3380-A, a 3-in. extension and 5/16 socket.
(4) Back off front band adjusting screw 2-1/2 turns
for the 30RH and 2-1/4 turns for the 32RH.
(5) Hold adjuster screw in position and tighten
locknut to 41 Nm (30 ft. lbs.) torque.
(6) Lower vehicle.
REAR BAND ADJUSTMENT
The transmission oil pan must be removed for
access to the rear band adjusting screw.
(1) Raise vehicle.
(2) Remove transmission oil pan and drain fluid.
(3) Loosen band adjusting screw locknut 5-6 turns.
Be sure adjusting screw turns freely in lever.
(4) Tighten adjusting screw to 5 Nm (41 in. lbs.)
for the 30RH and 8 Nm (72 in. lbs.) torque for the
32RH (Fig. 181).
(5) Back off adjusting screw 7 turns for the 30RH
and 4 turns for the 32RH.
(6) Hold adjusting screw in place and tighten locknut
to 34 Nm (25 ft. lbs.) torque.
(7) Position new gasket on oil pan and install pan
on transmission. Tighten pan bolts to 17 Nm (13 ft.
lbs.) torque.
(8) Lower vehicle and refill transmission with
Mopart ATF Plus 3, Type 7176, fluid.
Wheelin98TJ is offline
post #5 of 17 Old 02-01-2009, 10:13 PM
CCJ
Do us 4-spd auto guys have a band to adjust?
CCJ is offline
post #6 of 17 Old 02-01-2009, 11:30 PM
otisdog
2008 WK
No - the 42RLE has no bands.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #7 of 17 Old 02-01-2009, 11:43 PM
CCJ
Jim
Thanks Otis.
CCJ is offline
post #8 of 17 Old 01-04-2010, 03:00 PM
TJ_Jerry
Jim
I have the 42 RLE and I used to play in a band.
No matter how smart you might feel that you are. Remember there once was a time your main goal was learning not to crap in your pants. True evolution is an awakening.
TJ_Jerry is offline
post #9 of 17 Old 02-04-2010, 04:30 PM
autopc25
Originally Posted by Wheelin98TJ View Post
From the FSM:
(1) Raise vehicle.
(6) Lower vehicle.
(1) Raise vehicle.
32RH (Fig. 181).
lbs.) torque.
Is this adjustment for a 1997 3 speed auto also?
autopc25 is offline
post #10 of 17 Old 02-04-2010, 04:38 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
yes, same transmission.
Mail crawling.
MisfitSeven is offline
post #11 of 17 Old 02-04-2010, 04:45 PM
UTWeezul
Just curious, what exactly would this do?
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #12 of 17 Old 02-21-2010, 08:29 AM
autopc25
Anyone do this and what improvements?
autopc25 is offline
post #13 of 17 Old 02-21-2010, 12:13 PM
cj847
IMHO....this is the most useless item on the planet.
I have never seen or heard of an automatic tranny that needed the bands adjusted (other than at overhaul). I have also never heard of an auto that was having a problem that band adjustment fixed long term (but I'm only 50 years old).
I really think you are more likely to screw something up than to fix and/or improve the life of your transmission by making this adjustment.
You may have noted that on many new cars there is not even a recommendation to change auto trans fluid as a maintenance item for the entire life of the vehicle. If your tranny is working good the main thing that will kill it is contamination (dirt or water) or heat.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #14 of 17 Old 02-21-2010, 12:30 PM
jondotcom
I had a th350 tranny that slipped like crazy. After a band adjustment the tranny worked like new. A lot of transmissions get rebuild when they only need a band adjustment.
I would only recommend adjusting the tranny if it feels like something is wrong.
It will take time to restore chaos- GW Bush
jondotcom is offline
post #15 of 17 Old 02-21-2010, 12:36 PM
dlporter
2011 JK Wrangler
If your tranny is working good the main thing that will kill it is contamination (dirt or water), heat, or transmission flushing at Jiffy Lube.
Fixed it...
dlporter is offline
Adjusting bands on my 98 tj 30 rh haulincats TJ Wrangler Technical Forum 6 06-20-2009 03:46 PM
Idle Speed with Auto trans Nonya TJ Wrangler Technical Forum 5 12-12-2008 12:55 PM
3 Speed Auto Trans Temp BEANS TJ Wrangler Technical Forum 8 02-12-2006 05:58 PM
Adjusting indicator on auto trans shifter? TravisB TJ Wrangler Technical Forum 8 08-31-2005 07:17 PM
The 4 Speed Auto Trans? Ragtop_Rob TJ Wrangler Technical Forum 8 07-16-2005 10:32 AM
