Adjustable VS. Non adjustable Control Arms - JeepForum.com
post #1 of 4 Old 12-04-2006, 06:39 PM Thread Starter
Daylan
How much more articulation do you get with adjustable control arms over non adjustable control arms?
Daylan is offline
post #2 of 4 Old 12-04-2006, 06:45 PM
okeefe11
non, they allow you to set a desired length to your control arm in the chance you make suspension changes.
2002 Jeep Wrangler X
4" suspension lift/currie anti-rock
33" Mickey Thompson Baja MTZ
Front & Rear ARB plus 4.56 gear
Front & Rear Warn Bumper w/9.5ti on Front
Poison Spyder Rocker Guards
okeefe11 is offline
post #3 of 4 Old 12-04-2006, 11:02 PM Thread Starter
Daylan
So if I don't plan on going anymore than 4" with 33's I would be better off buying a cheaper lift with only the lower non-adjustable arms and disco's than I would spending more for a kit with front and rear uper and lower adjustable arms?
Daylan is offline
post #4 of 4 Old 12-04-2006, 11:10 PM
NavinRJohnson
Depends on what your goals are. If you just want to flex off road, there will not be a substantial difference whether you have adjustable control arms.
What the adjustable arms do is allow you to dial in your suspension angles. This will decrease bind in the suspension while you are flexing and put far less strain on various components of your rig (e.g., U-joints, control arm brackets, driveshafts, whatever). The biggest area I think it makes a difference is on road handling and ride. Having everything aligned properly is good thing when following a winding road at 70 mph.
That's my naive, inarticulate take on it anyway.
The D35: 60% of the time, it breaks every time.
'06 LJ (specs in profile, 35's, ARBs, rocket boosters, stealth technology, etc.)
NavinRJohnson is offline
Do I need Adjustable control arms? Tray2 TJ Wrangler Technical Forum 6 11-22-2009 10:07 AM
RE adjustable control arms Jeep14636 TJ Wrangler Technical Forum 7 11-05-2009 07:20 PM
Adjustable Control Arms Daylan TJ Wrangler Technical Forum 8 01-03-2008 02:23 AM
Adjustable Control Arms with OME HD....? thejafe TJ Wrangler Technical Forum 2 03-20-2006 04:42 AM
Where to get adjustable control arms? Scafone TJ Wrangler Technical Forum 16 10-09-2003 06:08 AM
