Which adjustable TB - JeepForum.com
post #1 of 35 Old 05-11-2013, 02:28 AM Thread Starter
glee1229
Which adjustable TB
I'm looking into buying an adjustable track bar and narrowed it down to two options. The Rough Country or Iron Rock Offroad, both double shear (Currie and JKS is out of my budget). I am leaning towards IRO, however, I can't decide on one factor. RC uses a bushing on one end and a heim on the other. While IRO uses bushings on both ends. Which would be the better choice? Thank you.
glee1229 is offline
post #2 of 35 Old 05-11-2013, 05:34 AM
brianmlove
In this instance rc one sunce it has a heim joint
brianmlove is offline
post #3 of 35 Old 05-11-2013, 06:34 AM
rchase559
Whatever one has the best clearance at full bump is what I would be more concerned about.
rchase559 is offline
post #4 of 35 Old 05-11-2013, 07:23 AM Thread Starter
glee1229
I've read great stuff about the IRO's, but from XJ forums. I haven't seen a lot of TJ owners use them. The IRO looks to be a lot stronger than the RC. Also I used to have a RE TB with heim and the joint got all wore out. I've read mixed opinions to use heim in steering components. Any additional help please?
glee1229 is offline
post #5 of 35 Old 05-11-2013, 07:56 AM
Patrick H
From other people's experiences, JKS and Currie are the only ones that clear without large amounts of bump stop extension.
http://www.jeepforum.com/forum/f9/tj...it-fit-738948/
My experience with heim joints is that they don't last very long before they wear enough to start rattling.
I run the JKS on the front. I don't know what your budget is, but I paid $196 from Amazon just a few months ago.
'01 TJ
'48 CJ2A
Patrick H is offline
post #6 of 35 Old 05-11-2013, 08:22 AM Thread Starter
glee1229
I was looking into getting a double shear set up. JKS doesn't have this, correct? Which one did you get? Is it better or equal to getting a double shear?
glee1229 is offline
post #7 of 35 Old 05-11-2013, 08:42 AM
Ljcrawler05
Have you checked out metalcloak's? They are relatively inexpensive and I've heard good things about them.. you can give metalcloak a call and they'll give you more info
Ljcrawler05 is offline
post #8 of 35 Old 05-11-2013, 08:45 AM
Patrick H
OGS126. Single shear. It has a 9/16" bolt at the frame end. Currie has 9/16" and they also have it with a 5/8" bolt. I figure if it ever gives me issues with the 9/16" bolt, I can swap the ball shank portion of the Johnny Joint to a 5/8" diameter.
'01 TJ
'48 CJ2A
post #9 of 35 Old 05-11-2013, 08:50 AM Thread Starter
glee1229
I read good reviews about them also. However, I am wanting to get a double shear TB.
glee1229 is offline
post #10 of 35 Old 05-11-2013, 08:52 AM
Patrick H
Sorry then, my posts are for naught.
'01 TJ
'48 CJ2A
post #11 of 35 Old 05-11-2013, 07:53 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if you want a double shear front mount that will actually work you need to cut the stock cast mount off and fabricate/build your own track bar & mount that clears at full bump.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 35 Old 05-12-2013, 09:41 PM Thread Starter
glee1229
I'm leaning towards getting the IRO track bar. But I have a question. Does the track bar need to have forward and back movement also instead of just having up and down movement. Because many other double shear TB come with a heim or JJ. I'm sure this is a plus, but I don't see why a TB must have a joint like that on the frame mount side. IRO comes with poly bushings on both ends. I've only read so many positive things about the IRO track bar that I keep going back on deciding to get it. However, I have not seem many TJ's running this (more XJ's).
glee1229 is offline
post #13 of 35 Old 05-12-2013, 09:43 PM
rchase559
Does your axle travel straight up and down as it cycles?
post #14 of 35 Old 05-12-2013, 09:48 PM
Unlimited04
The reason you haven't seen many TJ's running a double shear drop bracket is because they hit the tie-rod and wreck your uptravel.
Proof: http://www.jeepforum.com/forum/f9/ru...stion-1520793/
Here's IRO's vendor thread.....their track bar needs 3" bumpstop extension. That puts you at a minimum of around 5-6" of lift based on shock length.
http://www.jeepforum.com/forum/f43/t...rsion-1475938/
Once again, like I already said, if you want a double shear that will actually work, you need to cut the stock mount off and build your own setup. it's been done. there is some DIY builder support to do it. there is no write-up, there is no kit...you have to build it.
Useful Write-Ups:
Funny:
post #15 of 35 Old 05-12-2013, 10:17 PM
scot68
Why are you so adamant about a double sheer arrangement?
scot68 is offline
