adjustable rear track bars - JeepForum.com
post #1 of 19 Old 12-15-2007, 04:31 PM Thread Starter
UTmike
UTmike's Avatar
I'm looking for an adjustable rear track bar to use with my 8.8. I was checking out the JKS ones but if you have a SYE/CV then you have to buy a special bracket for it, but that bracket won't fit on my MORE 8.8 brackets, so JKS is out. Do any of y'all know of an adjustable rear track bar that will work on an axle tilted back for the pinion angle that doesn't require additional bracketry?
4.5" RE Long Arm, 37" Mud Grapplers on Beadlocks, OX Locked Dana 60s front and rear
UTmike is offline
post #2 of 19 Old 12-16-2007, 08:32 AM
sportcoupe
I don't see a connection between an adjustable track bar and a sye/cv driveshaft. I believe you are stating your question wrong.
sportcoupe is offline
post #3 of 19 Old 12-16-2007, 10:14 AM
daveshan
Feeding the money pits
daveshan's Avatar
??? Is my JKS bar not working right? I've done an SYE/CV and adjusted the pinion angle there is no binding that I can see. Or is it overstressed bushings that will cause a failure in the future? Of course I have the D44, there may be a difference there or I may have missed something.
Dave Shannon
Durango, CO
Gone but not forgotten
'56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr
daveshan is offline
post #4 of 19 Old 12-16-2007, 10:21 AM
robncar
robncar's Avatar
When you install the SYE/CV, you rotate the rear axle housing to achieve proper pinion angle. This rotation changes the relationship (angle) of the trackbar axle mount too and must be mitigated.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #5 of 19 Old 12-16-2007, 10:22 AM
RLD831
RLD831's Avatar
I have the same problem,but I didn't know until your post that the adapter brackets won't fit on the MORE brackets. Right now it just sqeaks while I drive and although I hate the noise, it still works. Are you sure that the JKS and the RE won't fit on the MORE brackets? Do you know why they won't? Right now I'm using the RE adj trackbar.
RLD831 is offline
post #6 of 19 Old 12-16-2007, 11:33 AM Thread Starter
UTmike
UTmike's Avatar
I have the RE CV bracket and can't put it on b/c the bracketry isn't the same as the stock bracket. After a little more research, it looks like ProComp makes an adjustable that is suppose to work w/the CV driveshaft. I'm gonna give them a call on monday before ordering though.
UTmike is offline
post #7 of 19 Old 12-16-2007, 12:18 PM
daveshan
daveshan's Avatar
Yea I saw that the angle of the bracket changed with the rotation of the axle. However the JKS is a threaded adjustable trackbar, you just loosen the nut and the axle end of the bar swivels to meet the stock bracket on the axle. There is no rubbing/binding or squeaking although the gas thank skid is darn close.
Dave Shannon
Durango, CO
daveshan is offline
post #8 of 19 Old 12-16-2007, 01:11 PM Thread Starter
UTmike
UTmike's Avatar
Well this is what the JKS site says about their track bars. They have two kinds. The first one says, "Vehicle must be equipped with slip yoke-type rear driveshaft w/ single cardan U-joint." The other one says, "Requires axle bracket (PN OGS160 or equivalent) designed for CV type driveshaft." And since the axle bracket won't fit on my bracketry I can't use either of the JKS trackbars.
UTmike is offline
post #9 of 19 Old 12-28-2007, 09:35 PM
john NC
john NC's Avatar
1979 CJ5
their website confused me, i'm looking at the one for 0-6" of lift (OGS153) (i have about 2")
http://northridge4x4.com/proddetail.php?prod=JKS-OGS153
will this work with the stock mounting brackets or will i need their bracket? i know the RE needs a bracket and i'd rather skip that part. i'm thinking i'll need it when i get my new tires on monday so they don't rub on the spring perch (would it be ok to grind a little off until i get an adjustable track bar?)
thanks
john NC is offline
post #10 of 19 Old 12-28-2007, 09:56 PM
FTW Rubi
FTW Rubi's Avatar
Usually, you dont need a adj trackbar until after 3"++ of lift. It seems that(by looking at my rear trackbar after a TT) the stock trackbar bushings are in a bind and it is rubbing the gas tank skid. I will be getting the jks adj trackbar and bracket. The trackbar keeps your axles centered under the jeep, as you lift it the trackbar pulls the axle to the passenger side. Your front will do the same. This is not noticed until after 3"+ of lift.
FTW Rubi is offline
post #11 of 19 Old 12-28-2007, 10:18 PM
john NC
john NC's Avatar
1979 CJ5
just by looking at my tires in relation to the spring perchs, i can see that the right rear is about an inch or less from the tire, i'm about to go from 9.5 to 10.5 inch wide tires so it may rub, if it does i'll be getting an adj trackbar and if not it'll wait
or i could just get new wheels which would be way cheaper once i think about it lol
john NC is offline
post #12 of 19 Old 12-28-2007, 10:33 PM
FTW Rubi
FTW Rubi's Avatar
Okay, right rear(passenger rear) is less than 1" from the upper spring perch. On my 03 the rear track bar mounts to the frame on the passenger side, and to the axle on the driver side. As I added lift (3" BDS springs)it pulled to the passenger side. Unless Jeep changed up the mounting of the trackbars then yours should do the same. You should not have to get either the adj trackbar or the new whells to just go to a 10.5. There is something else not cool. Break out your creeper and have a good close look at your under carriage.
FTW Rubi is offline
post #13 of 19 Old 12-28-2007, 10:36 PM
tcox
im using the RE adjustable track bar. i think the bracket is so you can use your stock track bar because the axle end is fixed, but on the adjustable, it is, well, adjustable
stuff
tcox is offline
post #14 of 19 Old 12-28-2007, 10:37 PM
FTW Rubi
FTW Rubi's Avatar
[IMG]<img src="http://www.jeepforum.com/gallery/files//1/1/3/3/3/5/p_adjtrack.jpg" alt="jks rear trackbar" />[/IMG] check this out.
FTW Rubi is offline
post #15 of 19 Old 12-28-2007, 10:53 PM
Ichabod1960
Have Jeep, Will Travel
Ichabod1960's Avatar
I would call up JKS or Northridge and ask them which rear Trackbar would work with your application. I haven't installed a SYE/new driveshaft yet but I'll be real disappointed if I can't keep my JKS Trackbar.
Drew
Originally Posted by Jerry Bransford
There's a great lower division class called "Writing for Effective Communications so you don't go through the rest of your life confusing everyone who reads what you write 101" at Washington State University. I highly recommend it.
Ichabod1960 is offline
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 09:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 04:07 PM
Rear adjustable track bars. chutta TJ Wrangler Technical Forum 3 04-01-2008 03:58 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 05:15 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 07:15 PM
