Adjustable Rear Track Bar - JeepForum.com
post #1 of 8 Old 06-26-2011, 05:31 PM Thread Starter
djflyy
I'm in need of an adjustable rear track bar for my TJ after doing my 8.8 install from ECGS. I tried to get the stock one to fit but it would NOT go (even after managing to break a 4,000 lb come-along trying to manually winch it over.
I need suggestions for adjustable rear track bars. Ideally, $150 will be my cap. I don't need Johnny Joints and can't afford Currie stuff although I'd like to be able to... I've spent a good deal this last few months moving to 35s and don't have excess laying around. I'm wondering if anyone has experience with the Rough Country rear, as my "local" Jeep shop which is an hour way, is a supplier. I need to get this back on the road sooner than later so I'd be able to drive up tomorrow.
Any suggestions would be great. Stats are 3" suspension lift, and an 8.8 in the back.
djflyy is offline
post #2 of 8 Old 06-26-2011, 05:36 PM
Gary2
I have an old Rubicon Express rear track bar in mine for about a year and a half now. I also have an 8.8 but I can't remember what brand brackets I used .
Gary2 is offline
post #3 of 8 Old 06-26-2011, 05:47 PM
Shadowline
just put one of these recently on a friends TJ.... worked fine and the price was right.... http://www.quadratec.com/products/16007_006.htm
2003 TJ 4.0 5-speed 31inch Goodyear Authority's, 2inch Rubicon Express Springs, Hella Vision Plus H/L's, IPF upgraded H/L wiring harness. JCR Offroad Stage 2 Frt Bumper with CocaCola Bottle opener, Smittybuilt XCR8 Winch, Rampage Bowless top.
Shadowline is offline
post #4 of 8 Old 06-26-2011, 05:47 PM Thread Starter
djflyy
Thanks for the reply, Gary. When you say brackets... are you referring to the axle side's? Mine came with the welded post from ECGS. No problems with the RE?
djflyy is offline
post #5 of 8 Old 06-26-2011, 05:49 PM Thread Starter
djflyy
Thanks, I'd looked at that as well. Glad to hear it worked well. If the guy at Steve's Jeep Country has that I'd consider it over the RC.
djflyy is offline
post #6 of 8 Old 06-26-2011, 05:55 PM
Gary2
Yes the axle mount was aftermarket as well as the rest on the axle . I don't know if they are all the same height which may have something to do with the length of the track bar needed. I can't remember if it even makes a difference on the rear . I know front track bars are usually a different model after like 3.5-4" of lift . Sucks getting older , memory just isn't what it used to be I guess its time to start writting things down .
Gary2 is offline
post #7 of 8 Old 06-26-2011, 10:01 PM Thread Starter
djflyy
bump for the overnight group
djflyy is offline
post #8 of 8 Old 06-27-2011, 05:32 AM
msutherland29
The JKS #153 works with the ECGS 8.8, I have the same axle and trackbar, just put it in last week, picked it up on Ebay for $140ish shipped to my door. Q-tec will be a bit more but if you need it yesterday the extra $$ might be worth it.
msutherland29 is offline
adjustable , rear track bar , rough country , track bar
Rear Track bar ? should i get the extension bracket or a adjustable track bar odyssey017 TJ Wrangler Technical Forum 8 05-10-2011 08:20 AM
Rear adjustable track bar: RE vs. JKS armyRN TJ Wrangler Technical Forum 0 06-20-2009 12:44 PM
TJ adjustable rear track bar for BB captndiltz TJ Wrangler Technical Forum 5 04-25-2009 08:56 AM
Which adjustable rear track bar is right for me? whiteguyjames TJ Wrangler Technical Forum 7 02-17-2009 10:50 AM
RE adjustable rear track bar??? NYwranglanator TJ Wrangler Technical Forum 5 04-21-2007 05:32 PM
