Adjust control arms, where to start?
| BLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 Trans | NEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers | 3/8" Amsteel Blue Winchline Available in Blue, Green, |
#1 | |
Location: Somewhere between the Port of Indecision and South of Disorder
I have a 2000 TJ. Running stock CA's right now with a 2" BB. I'll be doing a Belly up with SYE and 4"RE spring lift. I have Teraflex Flex arms both upper and lowers for front and rear. Adjustable front track bar, shock relocation brackets for the the rear shocks and rear track bar relocator.
My question is..... where do I start as far as length of the control arms when I install the lift. ( can I pre-set the ca's length) And should I do the lift first and then the belly up or vice versa?
[I][B][COLOR="Red"] Some people wonder all their lives if they've made a difference. The Marines don't have that problem. [/COLOR][/B][/I][COLOR="Blue"][B]- Ronald Reagan[/B][/COLOR] [COLOR="Green"][B][SIZE="3"]God grant me the serenity to accept the impossible trails I cannot crawl, courage to crawl the twisted trails I can, and the wisdom to keep the rubber side down.[/SIZE][/B][/COLOR] [U][COLOR="Red"][B]Red Jeep Club Member #408[/B][/COLOR][/U] [U][COLOR="Blue"][B]Low Output 4 Cylinder Jeep Club Member #77[/B][/COLOR][/U] [SIZE="5"][B][COLOR="Blue"][URL="http://www.rrr4x4.com/"]Rainier Ridge Rams[/URL][/COLOR][/B][/SIZE] |
#2 |
http://www.yuccaman.com/jeep/re_db.html#arms
Use that to get in the ballpark then adjust to center the wheels and for pinion angle. No worries.
2000 XJ, 5.5 lift, locked 8.8,SYE, homemade bumper/sliders,skids, other stuff |
#3 | ||
You can also use some basic geometry to make a guess at how long your ca's need to be. Just assume that the center of the axle housing is the center of the wheel, measure and use the good ol' pythagorian theorem (engineering student, can't help it.) that should give you an approx. length for how long to set the CA's. Also, make sure they are the same length so the axle will be square.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
