Adjstable control arm stretch - JeepForum.com
post #1 of 11 Old 07-14-2010, 02:22 PM Thread Starter
DAMRON
How much could I stretch my wheel base by installing the full set of short Currie or Rough Country control arms? I was hoping to maybe get about 2 inches more than I have now. I think I lost some due to using stock control arms with the 3 inch lift and it is giving me negative caster problems in the front. Anybody got any words of wisdom on this?
DAMRON is offline
post #2 of 11 Old 07-14-2010, 02:35 PM
Niceface
I gained about 1-1/2 inch in the front and 1inch in the rear.
This was due to the currie hd steering. I started rubbing in the front when turning passanger.
In the rear is the gas tank skid. Good luck
Niceface is offline
post #3 of 11 Old 07-14-2010, 03:29 PM Thread Starter
DAMRON
Thanks Niceface, That's what I was hoping for. Does anyone have experience with the Rough Country X Flex arms. The set of 8 is just $700 bucks, a little cheaper than the Currie ones.
DAMRON is offline
post #4 of 11 Old 07-14-2010, 03:43 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The correct answer is you can stretch it in the back until you stuff a 35" tire on the bumpstops without the springs in and the tire rubs the front and back lower edges of the wheel opening.
In the front you can stretch it until you start rubbing the draglink TRE on the trackbar mount or smacking the diff into the trackbar at full stuff.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 11 Old 07-14-2010, 03:47 PM Thread Starter
DAMRON
Thanks Mr. Blaine, I plan on doing some trimming of the rear wheel openings in necessary. I was just wondering how many inches I could stretch it if I needed to. It sounds like the short arms will give me all the flexibility I need.
DAMRON is offline
post #6 of 11 Old 07-14-2010, 03:49 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
look at Rokmen arms...they have a little more lengthening flexibility than the Currie arms.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 11 Old 07-14-2010, 03:50 PM Thread Starter
DAMRON
Another thought. How difficult is it to install adjustable control arms. I was just under there a minute ago because I am installing a PA 1 inch BL and Brown Dog Motor monts today. It looks easy enough. I figured I could do them one at a time so that I would not have too many problems with the axel being hard to move.
DAMRON is offline
post #8 of 11 Old 07-14-2010, 03:51 PM Thread Starter
DAMRON
I'll look at hte Rockmen ones right now.
DAMRON is offline
post #9 of 11 Old 07-14-2010, 03:51 PM
Unlimited04
not Rockmen. Rokmen. Rokmen Gear Up....Rok On
Useful Write-Ups:
Funny:
post #10 of 11 Old 07-14-2010, 03:55 PM Thread Starter
DAMRON
Luckily the search engine knew what I meant. Those are beefy but more expensive than I was planning. Opinions on the Rough Country X FLex arms?
DAMRON is offline
post #11 of 11 Old 07-14-2010, 04:19 PM
Niceface
I went with Clayton's for all lowers, and Rokmen for all uppers.
I'll say Sean and Rokmen DOES take care of his customers. Very nice guy and a pleasure to deal with.
Niceface is offline
control arm , suspension , articulation , stretch , ca , adjustable
Stretch or Adj. Control Arms? AlTheKillerr TJ Wrangler Technical Forum 12 12-28-2009 08:52 PM
Clayton's long arm and 5" stretch or the double triangulated with the stretch? Haz-Mat TJ Wrangler Technical Forum 14 08-14-2009 08:44 PM
Slight Stretch on Adjustable Control Arms ScottyR TJ Wrangler Technical Forum 8 03-02-2009 12:05 PM
anyone tried the clayton stretch kit or a custom stretch setup bluejeep2088 TJ Wrangler Technical Forum 5 02-01-2007 09:04 PM
YJ - XJ stretch kit 5.0YJ YJ Wrangler Technical Forum 38 10-06-2006 11:37 PM
