Quantcast Adj. Track Bar Questions... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Adj. Track Bar Questions...
Old 05-28-2007, 09:27 PM   #1
xulcuz
Are Tj and cherokee track bars the same thing? I went to my local 4x4 store and they didnt have any TJ ones but they said that the cherokee ones were the same thing and that they had one of those. I am strugling to get this on there and I dont see it fitting? Does anye one have a pic of theres? Also I have a dana 44 would that have anything to do with it? PLease help me this is my DD and I need it back asap.
xulcuz is offline   Reply With Quote
Old 05-28-2007, 09:29 PM   #2
RnEmOvr
Never Forget
RnEmOvr's Avatar
for front or rear? and what years both tj and xj
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 05-28-2007, 10:04 PM   #3
xulcuz
Sorry should have included that. Its the front track bar. My Jeep is a 2003 Rubicon but I have no idea what year the track bar on the cherokee is the 4x4 place just told me they were the same so I said ill take it home and try it. Well I tryed couldnt get it so I called them back and asked if they were sure they were the same and tehy said yes but bring it back if you have trouble. Well Im having trouble but instead of going through the trouble of driving out there to bring it back again I figured Id ask first. I will get some pcis tomarow but if you can help me out now that would be awsome!
Thanks
Old 05-29-2007, 09:10 AM   #4
xulcuz
Any one? I could really use some help here!
Old 05-29-2007, 09:26 AM   #5
robncar
What brand is it? I was looking at the RE site and the RE1600 is compatible with both TJ and XJ...
robncar is offline   Reply With Quote
Old 05-29-2007, 02:38 PM   #6
xulcuz
It is a BDS adjustable track bar. Ill get pics tonight and can some one else show me a picture of theres mounted? Thanks for the help! zi really need to get this figured out!
Old 05-29-2007, 02:52 PM   #7
fourtwenty
Some adjustable track bars require you to drill out one of the bolt holes. I would think it would say that in your instructions if that was the case here. You have read them, right?
Edit: I've also heard that there are some issues with adjustable track bars rubbing on the D44. Check out www.******************.com for more info.
Current Jeep: 2004 WJ Limited, stock.
Past Jeeps: 1999 Cherokee, 2003 Rubicon, 1987 Cherokee, 1976 CJ5, another 1987 Cherokee, 1976 CJ7, 1983 CJ7, 1977 CJ5, 1982 CJ7.
fourtwenty is offline   Reply With Quote
Old 05-29-2007, 07:10 PM   #8
xulcuz
Bump for more info please.....
Old 05-29-2007, 08:33 PM   #9
xulcuz
Ok I think I have the wrong one because mine only has one bend in it were as all the other ones im seeing have 2 in them so I guess I will be bringing it back.
Glock Forum
