Quantcast adj. rear track bar questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > adj. rear track bar questions
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 03-21-2008, 11:41 AM   #1
skeebs
skeebs's Avatar
I have been trying to find the "right" equipment for a while now. I need more answers.
I have 3" of suspension lift right now, might go as high as 4", but not any time soon (and definitely no higher than 4"). I have dropped the t-case until I can afford an SYE/CV conversion, which won't be anytime soon.
Are their adjustable rear track bars out there that DO NOT require an additional bracket to install (looking for one to bolt right into OEM mounting points)?
would an RE 1620 adj. rear track bar mount into another bracket (such as an OME)?
I have gotten a few quotes on RE's (reasonable pricing), but the additional bracket idea - I don't like. Nor do I like the fact that I have to drill out the stock mounting hole for the front track bar....then I'd pretty much be stuck with RE if I destroy this thing somehow wheelin.
Please give me some advice fellas, I want to make a purchase ASAP so I can get this stuff installed to smooth out my Jeep.
skeebs is offline   Reply With Quote
Old 03-21-2008, 11:54 AM   #2
Crashnburn80
Yes, JKS makes one, 3rd down on the list, for 0-6" of lift.
http://store.jksmfg.com/merchant2/merchant.mvc?Screen=ADJTRACK&Store_Code=JKS01&Cate gory_Code=Trackbar_Components
It says a different bar is needed once going to an SYE over 3", I currently am running a CV driveshaft right at 3" of lift and the standard JKS adjustable track bar listed above works fine. At 4" of lift though the axle rotation for the pinion angle correction for the CV may be to great, which will require a bracket regardless of the brand.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Glock Forum
