Adj. Front Trackbar Help - JeepForum.com
post #1 of 16 Old 08-05-2009, 09:00 AM Thread Starter
Tcormier106
I am going to be installing the Rough Country 3.25" lift without the rear spacers and with a 1" body lift and MML.
What adjustable front trackbar does everyone recomend?
I was looking at one from teraflex but am open to suggestions.
Tcormier106 is offline
post #2 of 16 Old 08-05-2009, 09:06 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
RC's new one is very good.
TheBoogieman is offline
post #3 of 16 Old 08-05-2009, 09:14 AM Thread Starter
Tcormier106
I didn't know they came out with a new one, I had heard some mixed reviews about their older one so I started to move away from it. So basically the new one is on par with most of the other stuff on the market for reliability?
post #4 of 16 Old 08-05-2009, 09:27 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Jks........
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 16 Old 08-05-2009, 09:32 AM Thread Starter
Tcormier106
The only problem I have with JKS is that I have read a lot of reviews about it hitting the D30 diff cover. JKS claims there may be some interference with the D44 but lots of people have apparently had problems with the D30.
post #6 of 16 Old 08-05-2009, 09:49 AM
sandjunkie
Currie Enterprises
sandjunkie is offline
post #7 of 16 Old 08-05-2009, 09:51 AM
TheBoogieman
The older ones barely fit with a 4" lift and wouldn't work on anything smaller.They also weren't as thick as the newer ones.Here's a link.
http://www.roughcountry.com/jeep_xtras_1083.html
post #8 of 16 Old 08-05-2009, 10:17 AM
Unlimited04
yup mine hits my Riddler diff cover, but only off-road at full flex when the drivers side is stuffed, or at full compression of both front springs.
Useful Write-Ups:
Funny:
post #9 of 16 Old 08-05-2009, 10:25 AM Thread Starter
Tcormier106
boogieman is the rough country one what you are currently running?
post #10 of 16 Old 08-05-2009, 11:49 AM
TheBoogieman
Yup,I like it.
post #11 of 16 Old 08-05-2009, 11:56 AM Thread Starter
Tcormier106
thats what i wanted to hear, thanks a lot
post #12 of 16 Old 08-05-2009, 12:08 PM
rubidriver
Jks, Currie, or Nth (stock with a drop bracket that is fully brace)
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #13 of 16 Old 08-05-2009, 12:20 PM
kellerumps
kellerumps's Avatar
How do you make sure that the axel is centered? On another site, it says to lower the jeep before centering. I need some tips on this step.
Thanks
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #14 of 16 Old 08-05-2009, 12:24 PM
NotURMailman
NotURMailman's Avatar
You have to have the weight of the Jeep on the axle to center it. I always just put it on the ground and measure. Then I use a ratchet strap run from the frame to the axle to pull it over to center.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #15 of 16 Old 08-05-2009, 01:23 PM
mrgimble
2015 JK Wrangler
Or just turn the steering wheel a bit. If you have a friend.
mrgimble is offline
Front trackbar relocation by drill and rear trackbar relocation bracket install? loudog3114 TJ Wrangler Technical Forum 20 10-26-2014 07:01 PM
Do you need an adj front trackbar with the RC 3.25 chaznad TJ Wrangler Technical Forum 21 07-06-2010 08:28 PM
Front trackbar vs Adj LCA? Houndx TJ Wrangler Technical Forum 0 01-13-2010 06:55 PM
front trackbar YJ=TJ klincker TJ Wrangler Technical Forum 1 08-05-2009 09:13 AM
Adj. Front Trackbar Pipedrummer TJ Wrangler Technical Forum 2 01-07-2007 04:52 PM
