Ade-ii security install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Ade-ii security install
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 07-26-2011, 06:32 PM   #1
rslove
Did anybody else have an issue with wire length? I was really limited on where I could locate it. I don't know if my harness was built wrong but I had to cut the mesh and pull the grey wire with the switch on it because I had about 8 inches of wire to run from the box through the firewall. It would make mounting the reed switch easier if it reached the inside of the vehicle.
rslove is offline   Reply With Quote
