Adding to my 2 inch budget boost lift - JeepForum.com
post #1 of 29 Old 10-21-2013, 07:21 PM Thread Starter
Mahanoy
Hello I was wondering if I could add a 2 or 2.5 inch lift kit to my already installed budget boost lift kit.
Life is an Adventure Not a Destination ~Anonymous
Mahanoy is offline
post #2 of 29 Old 10-21-2013, 07:27 PM
Jeffro06
Jeffro06's Avatar
No.....well yes, but why would you?
Jeffro06 is offline
post #3 of 29 Old 10-22-2013, 02:50 AM
MetalMountainGoat
Sure you can!
It will ride awful and not flex worth a **** though. Buy a set of 3" springs and some new, longer shocks and you will be set.
MetalMountainGoat is offline
post #4 of 29 Old 10-23-2013, 03:49 PM Thread Starter
Mahanoy
I have had jeeps forever but I'm not to informed about lifts. If I put 3 inch springs and shocks what else will I need? Don't you need pitman arm, control arms n such?
Mahanoy is offline
post #5 of 29 Old 10-23-2013, 03:55 PM
Stop being a
You won't need a pitman arm, but you may need to address your driveshaft angle, however, you likely had to do something about your driveshaft angle with the 2" kit.
What is the lift for? Have you considered a 1" body lift? You would then have 3" of lift without having to mess with your driveshaft. Furthermore, with a bodylift and motormount lift, you actually help your driveshaft angle.
Stop being a is offline
post #6 of 29 Old 10-23-2013, 10:00 PM
MetalMountainGoat
The typical rule of thumb is that anything over 3 inches and you will need a slip yoke eliminator. You will not need a pitman arm, and control arms are optional with 3 inches and below. You may have to drop the t case a half inch or so with some washers, but that's an easy fix. Just whatever you do, don't add lift springs with spacers above an inch.
post #7 of 29 Old 10-23-2013, 10:22 PM
MrSundays
It all depends on what you want to run tire wise and what you will be doing. For up to 33" tires and stock fenders, its safe to say a 3" lift will suffice, but you can always do a 2" SL with a 1" BL. They do make complete kits, but its up to what your wallet wants.
SOLD- '13 JKR with lots of goodies
Current- '98 TJ Sahara: build coming in October
MrSundays is offline
post #8 of 29 Old 10-23-2013, 11:32 PM
oalali
It would be better to replace the whole thing with a 4" lift. Specially with a one that have the necessary "corrective" control arms.
oalali is offline
post #9 of 29 Old 11-02-2013, 08:00 AM Thread Starter
Mahanoy
I recently found a rustys Offroad basic 3 in suspension lift. It comes with 4 springs and the front ones are heavier than normal to accommodate my snow plow and it also comes with new shocks and a drop pitman arm and t case drops and a rear track bar relocation bracket. Any one have an opinion on this kit? It's $450. My wallet can handle it but I believe that's it. I go offroading about 3 times a year on the easier trails so I do not need an substantial $1000 lift kit.
Mahanoy is offline
post #10 of 29 Old 11-02-2013, 08:03 AM Thread Starter
Mahanoy
Also if anyone has any pictures of a tj with a 3 in lift can they please post them. The tires ill be running are 265x75x17. They are a metric 33 almost. They do not rub much now but when you flex the flares cut the edges of the tire to hell.
Mahanoy is offline
post #11 of 29 Old 11-02-2013, 08:56 AM
tyvanwie
That's a horrible idea.
tyvanwie is offline
post #12 of 29 Old 11-02-2013, 08:57 AM
tyvanwie
Bumpstop extension.
tyvanwie is offline
post #13 of 29 Old 11-02-2013, 02:43 PM Thread Starter
Mahanoy
Why is that lift a horrible idea? I have the bump stop extensions from the budget boost kit I got.
Mahanoy is offline
post #14 of 29 Old 11-02-2013, 03:55 PM
KBR97
The amount you go off-roading in a year has nothing to do with the money you should spend on a lift. Installing quality parts, and the "right" parts determines how your jeep will handle on the road as well.
Put a cheap crappy lift in your jeep and it will ride crappy. Regardless of how often you wheel.
Originally Posted by tyvanwie View Post
Bumpstop extension.
Apparently not the right ones. Thats why they hit your tires.
KBR97 is offline
post #15 of 29 Old 11-02-2013, 04:48 PM Thread Starter
Mahanoy
I was also looking at a rough country 4 in lift. Anyone have anything to say about them?
Mahanoy is offline
