Adding ATF after cooler install - JeepForum.com
post #1 of 6 Old 06-10-2014, 07:55 PM Thread Starter
05LJTampa
Im installing a transmission cooler this week for my 42lre transmission. Question is...im pretty certain i'll need to add more fluid since some of the fluid will be stored in the cooler. Do i just add the fluid in the fill hole of the transmission or can i add it slowly through the dipstick? If i add it to the fill hole i dont think i can get a quart in there since i just put the correct amount of atf when i did my recent fluid change.
05LJTampa is offline
post #2 of 6 Old 06-10-2014, 08:30 PM
Rangerz
Dipstick.
"Jeeps Love Gas Stations"
Chris - Lost Wages, NV
2002 Dodge Ram 2500 Diesel, 2009 Lance 825, 2005 TJ,
Polaris RZRs.
Rangerz is offline
post #3 of 6 Old 06-10-2014, 08:38 PM Thread Starter
05LJTampa
Originally Posted by Rangerz
Dipstick.
Thank you!
post #4 of 6 Old 06-10-2014, 09:10 PM
gregstudeny
2006 WK
Originally Posted by Rangerz View Post
Dipstick.
Its a valid question. No need for name calling. Just joking
gregstudeny is offline
post #5 of 6 Old 06-12-2014, 02:32 AM
thedaringmove
Make sure you let the engine idle in neutral for a while then fill it while its still on in neutral. Helps it all circulate
thedaringmove is offline
post #6 of 6 Old 06-12-2014, 02:42 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
On the OP's Jeep if the engine is running so is the fluid pump in the transmission, no matter what position the transmission shift lever is in... HTH
Knuckelhead is offline
