Adding an adjustable track bar - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Adding an adjustable track bar
Poison Spyder from CCOR!Rough Country Lift Kits and Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-29-2012, 05:09 PM   #1
Willu
Ive recently gotten the death wobble and i took it to a place that says that i need a adjustable track bar to fix it. Since i have a 4inch lift and stock track bar i guess its time to change it out anyway.
My question is if adding an adjustable track bar will affect my ride quality? And do brands really made a difference ride wise? My jeep sees little off roading so i wont need something heavy duty but i do made a 30min drive every day to work so i wouldnt want my ride quality suffering.
Willu is offline   Reply With Quote
Unread 06-29-2012, 05:15 PM   #2
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
it wont necessarily affect ride quality like shocks...but steering & driving quality, yes.
go with a Currie TJS or TJJ model. reinforce the axle side mount by welding some 1/8" plate to it, and make sure to run proper bumpstop extensions to keep the track bar from hitting the diff cover. also make sure your tires are road force balanced and the alignment is good (caster, toe, etc).
Unlimited04 is offline   Reply With Quote
Unread 06-29-2012, 05:52 PM   #3
Necromancer_tat
Mall Crawler
Necromancer_tat's Avatar
An adjustable track bar shouldn't change your ride quality. If your old track bar bushings are worn out the new trackbar should actually improve your ride. It's not a 100% cure all for DW though as there are many different things that can allow your Jeep to DW.
When someone tries to tell you that nothing is impossible, ask them to dribble a football!
Originally Posted by misterpookie View Post
my best recommendation is keeping a dictionary in the restroom.
word to the wise: dictionary pages are generally thin and not quilted. :nono:
Originally Posted by 1999TJRED85000 View Post
Are you on crack?
I think you're a little off. The shell on a turtle is thicker by a factor of 1.6783 while compared to the speed of a Puma, when chasing a rabbit. Therefore, if you hit a nail with a 4 lb. hammer, the thickness of the wood needs to be 4, and your grip should be on your lower regions.
Project "Wrong Way" Jeep build ----> http://www.jeepforum.com/forum/f22/p...g-way-1293197/
Project "Bassakwards" Jeep build---->http://www.jeepforum.com/forum/f22/b...build-1483076/
Necromancer_tat is online now   Reply With Quote
Unread 06-29-2012, 09:00 PM   #4
alex211
Currie TJS or TJJ are really the only good options out there. I put the TJJ on mine for the 1/2 bolt at the axle bracket.
03 TJ
Build thread - http://www.jeepforum.com/forum/f9/my-rubicon-build-thread-slow-1255392/
alex211 is offline   Reply With Quote
Unread 06-30-2012, 12:33 AM   #5
Willu
Can someone tell me what TJS and TJJ stand for please... Also the shop suggested a rubicon express adj track bar
Unread 06-30-2012, 05:23 AM   #6
rikkards
They are just a code. The TJS you need to drill out the Axle size hole and the TJJ you have to drill out both sides as the bolts are bigger than stock. The one thing no one says about this is that drilling them out then means you can't throw on another companies TB if you are in a pinch. However I have a TJJ and I would seriously doubt having to ever do that looking at how beefy it is.
"These are my Murder Sticks"
- Mantis Shrimp
rikkards is offline   Reply With Quote
Unread 06-30-2012, 06:14 AM   #7
Necromancer_tat
Mall Crawler
Those are model numbers for Currie trackbars.
Are you on crack?
Unread 06-30-2012, 06:41 AM   #8
Sundowner
Part-Time Swami
Sundowner's Avatar
Can someone tell me what TJS and TJJ stand for please...Also the shop suggested a rubicon express adj track bar
I'd call that a downgrade from either of the Currie units.
The build, the gear, and the mileage: The Wasteland Survival Guide
Sundowner is online now   Reply With Quote
Unread 06-30-2012, 07:02 PM   #9
Willu
but currie is pretty heavy duty isnt it? I dont go off roading that often and when i do its not that intense.. Is there something cheaper but still reliable?
Unread 06-30-2012, 08:23 PM   #10
Necromancer_tat
Mall Crawler
I run one, it's been doing alright for me so far.
Are you on crack?
Unread 06-30-2012, 08:39 PM   #11
Unlimited04
clearance problems are the concern. Currie TJS/TJJ models happen to be heavy duty, but they also have some of the best clearance available.
Unread 06-30-2012, 09:13 PM   #12
Sundowner
Part-Time Swami
Sundowner's Avatar
Oh, I'm sure it has...and I wasn't trying to imply that it wouldn't work for him as well: I just happen to think that Currie has some of the best track bars out there.
That was the basis of my earlier comment. I've got to get adjustables on mine, and in my opinion the Currie units are hard to beat for both this reason and the fact that you get a great set of joints, to boot.
ride quality , track bar
