Actual tire size for 32x11.5? - JeepForum.com
post #1 of 6 Old 05-12-2008, 01:53 PM Thread Starter
4bangerWrangler
I'm trying to get a price online, but all the sites require the 265/75/15 type of measurement. What's the measurement for a 32x11.5r15? Thanks!
Colemanitis
2000 Jeep Wrangler SE
4bangerWrangler is offline
post #2 of 6 Old 05-12-2008, 02:00 PM
JeepJohnson
A 265/75R15 would be a 31x10.50x15. If you have 16" wheels the most common 32" tire is a 265/75R16, which is a 32x10.50x16
Low Output 2.5L Member #39
Originally Posted by phaldor View Post
The top is a Barkertop...
Originally Posted by Capeman29 View Post
OH WOW, it electrically smashes all the fabric and windows together and looks like a big burnt marshmallow hangin off the back of your rig!!!!
JeepJohnson is offline
post #3 of 6 Old 05-12-2008, 02:02 PM Thread Starter
4bangerWrangler
Thanks, but I'm wanting a 32x11.5 on a 15" wheel.
Colemanitis
post #4 of 6 Old 05-12-2008, 02:03 PM
Cellar Dwellar
It converts to 292/74R15 which is not a real size. 295/75 R15 would be about 32x11.6 R15. I don't know if that is a real size either. Most 15" are sized in inches. R16's are usually in metric.
Cellar Dwellar is offline
post #5 of 6 Old 05-12-2008, 02:04 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #6 of 6 Old 05-12-2008, 03:15 PM
BlueFlame
BlueFlame's Avatar
It actually varies among manufacturers (often by a lot) but a 32x11.50R15 is generally around 31.5 x 11.0
<grin>
A quick and easy way to compare tire sizes is go to Tirerack.com and look at tires. They list sizes as spec'd by the manufacturers, not from some calculator. Example: http://www.tirerack.com/tires/Spec.j...irePageLocQty=
And if you are shopping online and their system won't take the 32x11.50 measurement, go elsewhere. Who knows what you will get. With a real tire retailer will be able to find the actual sizes of the tires you are looking at and not have to "convert" to something else.
BlueFlame is offline
rpm/gear calculators take actual tire height into account? citRon YJ Wrangler Technical Forum 16 08-29-2008 07:47 AM
Quick question, actual tire height Tkamplin YJ Wrangler Technical Forum 1 07-12-2008 01:14 PM
ACTUAL Tire Size Listing... Jim93YJ YJ Wrangler Technical Forum 5 06-05-2008 06:15 PM
stock gas tank actual size 97tjtom TJ Wrangler Technical Forum 12 02-09-2008 02:15 PM
Want to run 32x11.50x15 What size Lift? NDClown TJ Wrangler Technical Forum 51 02-07-2007 06:02 PM
