Accessory switches - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Accessory switches
Jeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!JcrOffroad: New XJ Rear Crusader Bumpers available!
Unread 11-07-2002, 08:24 AM   #1
Katch
Accessory switches
I'm not sure about what years this is included, but my 2002 has three little covers beside the cigarette lighter that the manual calls the accesory switch. Are the switches under the covers or do I have to buy the switch box? I'm mounting some offroad lights to my windshield, and I want to use the accesory port. If any of you have the switch-what other uses do you have for them(since there's three switch ports)? Thanks all.
Steve "Katch"
'02 Sport (pictures to come soon)
Katch is offline   Reply With Quote
Unread 11-07-2002, 09:18 AM   #2
RON310
The 3 switches in my jeep are:
Rear wiper
Rear Defroster
Fog Lights
All from Factory. I think you may need to buy the actual switches.
** Speaking of switches, Anyone know where to get the jet fighter type switches. You know, they are like toggle switches with a red flip up cover over them......anyone...........anyone?
RON310 is offline   Reply With Quote
Unread 11-07-2002, 09:34 AM   #3
MichiganTJ
To answer both of you... Painless Wiring makes all kinds of switches. I purchased a rocker switch that was a near perfect fit in the accessory switch panel. I bought it for $8 from macromotive.com. It looks great installed. The model # is 80404, although there are others to choose from as well.
They do actually make the aircraft style switches with the flip up covers, too! I'm not sure if you can purchase those from macromotive or not, though.
You can get more info from www.painlessperformance.com
1992 YJ -- 2.5L -- NP231 -- Stock ::SOLD::
2000 XJ -- 4.0L -- NP242 -- 2" BB ::SOLD::
2001 TJ -- 2.5L -- NP231 -- 31" BFG ATs ::SOLD::
MichiganTJ is offline   Reply With Quote
Unread 11-07-2002, 09:58 AM   #4
BeachJeepin'
they sell those fighter jet switch covers at summitracing.com I'm getting some soon.
The Past is Prologue...
BeachJeepin' is offline   Reply With Quote
Unread 11-07-2002, 11:06 AM   #5
Tyler Dirden
I dunno what kind of prices you guys are getting for these switches, but I know a guy in IN who sells 'em. I've bought tons of stuff from him before (I rice my PC, not my TJ). His name is Cole. Good products. Good guy.
switch it up, military style!
td
\oo/_ _\oo/
2003 Rubicon
'El Negro'
Tyler Dirden is offline   Reply With Quote
Unread 11-07-2002, 10:19 PM   #6
K9JEEP
Registered Abuser
The Accessory's panel uses normal 2"x1" block panel switches... Should be found at just about every automotive store for under $5. If you really wanna be sly, go to a marine store and get Water-resistant switches for $9.
HTH
K9Jeep
Http://www.dso4x4.com
K9JEEP is offline   Reply With Quote
Unread 11-07-2002, 11:34 PM   #7
BeachJeepin'
ok go to summitracing.com
Part Number: SUM-G3902C
Price $9.69
Love the way they look!!
Unread 11-08-2002, 08:36 AM   #8
Bucket110
if you want to go with the stock switch...looks the best, fits perfect...you are going to have to buy the whole fog light wiring harness kit from jeep in order to get the switch and the wiring harness into the switch...costs around $70. looks the best but expensive...
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear
2003 F350 diesel....tow rig
[COLOR=blue]NEJEEPZ[/COLOR]
[URL=http://community.webshots.com/user/2k2blktj]My Jeep[/URL]
Bucket110 is offline   Reply With Quote
Unread 11-08-2002, 09:47 AM   #9
01Sport
You don't need the whole wiring harness, just the switch. The switch is $30. If you want it to look factory, go for that, but if you don't care, buy another switch and just put it in. I soldered the wires for my KC's to the factory switch. Only thing I didn't get hooked up is the backlighting for the switch. It only lights up when my KC's are actually on.
Good luck and happy wiring.
01Sport is offline   Reply With Quote
Unread 11-08-2002, 10:39 AM   #10
Katch
Here's a kinda silly follow up question. Just so I don't mangle those three switch covers-do they easily pry off with a screwdriver, or do I have to remove the dash covers? Thanks.
Katch
Unread 11-08-2002, 10:45 AM   #11
01Sport
Take the plate off and remove them from the back.
Unread 11-08-2002, 10:54 AM   #12
Katch
Thanks 01Sport. You saved me some frustration if I tried prying with a screwdriver. By the way-what year is your Jeep?....Just kidding
Katch
Unread 11-08-2002, 11:07 AM   #13
macb
to get the whole switch mounting assembly out:
pull of the vent cover behind the windshield
you will see a couple of screws that hold on the plastic
dash center peice.
remove the ash tray and you will see a screw there as well
after you get the center 'cover' off you should have no problem
from there getting it out, I think it was only 1 screw holding it in.
you can access the wiring harness quite easily and wire in.
that was on a 2000 but I think they haven't made any changes
to the dash mounting for the TJ yet...
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah: [URL]http://www.sajeeps.com[/URL]
[url=http://www.cafepress.com/H2RT]No Bling - H2 Recovery Gear[/url]
Bob Supplee:supplee@ionet.net or (405) 799-8977
Stu Olson's great jeep resource site: [url=http://www.stu-offroad.com]www.stu-offroad.com[/url]
macb is offline   Reply With Quote
Unread 11-08-2002, 11:33 AM   #14
smunns
You can also get the stock switches at jeepsareus.com.
smunns is offline   Reply With Quote
Unread 11-08-2002, 04:13 PM   #15
4cornerzJeeper
I have the Summit switches but there not mounted in the dash. They are mounted to my cbrack
if link doesn't work, copy the properties into the address bar, that worked for me a few times.
or, go to my sig, then old photos.
97 Sport, 5spd, RE 5.5 in my closet, under bed, stacked in corners, and 35" MT/R's on balcony waiting to be installed. I'll have it done by the 2nd week of jan 03.
http://community.webshots.com/user/beadlocks
4cornerzJeeper is offline   Reply With Quote
accessory , switches
