AC re-charging question - JeepForum.com
post #1 of 10 Old 08-04-2010, 04:48 PM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
I am currently away from home, so I do not have my 'professional gauges' with me to check the ac, I bought a can of freon which came with a gauge connected to it.
When adding freon, the pressue doesn't change at all on the gauge. There are no leaks anywhere in the system (I have added dye, and checked everywhere). There was still freon in the system before I added, just not enough to get the inside of the jeep cold.
I only added freon for about 1 minute, when I noticed the gauge not moving I removed it and didn't add anymore (jeep still isnt blowing cold air). Do I need to add alot of freon to see a change in pressure? or is that gauge 100% worthless
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #2 of 10 Old 08-04-2010, 05:03 PM
Dogman
Dogman's Avatar
I would guess that you either have no pressure or the gauge is worthless. Not too helpful, but it's got to be one of the 2. You have the AC on high when you're doing this?
John 3:17
Dogman is offline
post #3 of 10 Old 08-04-2010, 05:05 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
You're sure the system is low on R134a, or did you just assume so because the air is warm coming out of the vents? Have you eliminated the heater box doors as the source of the warm air? A broken door or malfunctioning door or a disconnected vacuum hose could prevent the doors from operating properly, allowing warm air to mix in the heater box and get sent to the vents instead of cold air from the A/C evaporator.
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #4 of 10 Old 08-04-2010, 05:14 PM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
I have it connected to the low side (as directed on the instruction). There is def. pressure in the line, as the gauge indicates about 35psi (it is 105 degrees here right now so I need it close to 50psi). When disconnected the gauge reads 0psi. Man I wish I had the money to get a different gauge, but I blew $40 on this damn can
yeah, I moved the heater door manually with my hand (above pass. side floor) it is warm then super hot(when door opens heater box). The vacuum line is good (otherwise I would be getting air through the defrost vents). thanks for the questioning though
how long does it usually take to add freon to a vehicle? about 5 minutes? or is it something that should take a few seconds. Watching videos on youtube, people have the freon connected for about 3-5 minutes..
I am wondering if I just need to add alot.......???
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #5 of 10 Old 08-04-2010, 06:44 PM
BaddAndy
Does your compressor cycle on and off alot? I just added 2 big cans to my F-150. The gage would drop down to the low green range when cycled on, then med blue when off. Now it doesn't cycle anymore and reads a little into the blue with freezing cold air coming out of the vents.
2001 Jeep TJ Sport, SOLD!
2013 JK Sport, 6 Speed manual, RC 3.5" Series II, GY DTs 315/70/17, Pro Comp 7005s 17x8, Rubi 44s
BaddAndy is offline
post #6 of 10 Old 08-04-2010, 06:46 PM
jim.p
Sorry if this is to simple.
But the compressor is turning, right. A lot of systems shut the compressor off if the pressure drops to low to save the compressor. If it is not turning you will need to jumper the switch while charging. Just don't leave the jumper on and destroy the compressor.
jim.p is offline
post #7 of 10 Old 08-04-2010, 06:55 PM
TheDragonfly
When I used one of those cans on mine and it wasnt adding pressure, and the compressor was kicking on and off really fast. I took it in, and it had a leak and needed a new metal hose.
TheDragonfly is offline
post #8 of 10 Old 08-04-2010, 06:58 PM
conrasm
conrasm's Avatar
I added freon to my XJ in the past and it slows down as the can cools. I would let the can sit on the compressor as the hot air from the engine blew over it to get the freon going again. It takes a couple minutes for it go in.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #9 of 10 Old 08-04-2010, 07:09 PM
2jhanna
If you are low of freon, you DO HAVE a leak or else you would not need to add freon, it may be small, but freon does not get used up.
You could have any number of problems, like mentioned above, including blocked/clodded orfice.
jhanna
denton county, tx
2jhanna is offline
post #10 of 10 Old 08-04-2010, 08:12 PM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
yes, I meant that the leak wasn't BIG causing the freon to exit the system right away as I added it (no pressure change). I do have a small leak, which I have pin pointed to one of the schraeder valves, I am going on a trip tomorrow and ac would be nice
The compressor is turning on
I added just a little bit more of freon and now the temp in the jeep is getting to about 48 degrees, I guess once I get back to my garage I can hook up the real gauges and get it all perfect
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
ac , a/c , recharge , recharging , kit , tj , wrangler
Charging system question wolfen TJ Wrangler Technical Forum 2 03-28-2009 11:15 AM
Charging the AC GreyfoxVt YJ Wrangler Technical Forum 3 06-23-2008 06:53 PM
charging at 19V cosminciortan YJ Wrangler Technical Forum 8 07-08-2007 01:01 PM
Charging ? on a 88 YJ blackmax YJ Wrangler Technical Forum 1 03-21-2007 06:11 AM
Charging a TJ jeepramnauth TJ Wrangler Technical Forum 13 10-03-2004 11:48 PM
