AC Question/97 Wrangler - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > AC Question/97 Wrangler
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 03-02-2005, 07:19 AM   #1
Drunk Devil
I have a 97' Wrangler Sport with an AC unit that has recently been on the fritz. It still produces cold air (or hot if I use the heater), the problem is it only blows air intermittently. It seems to randonly decide when it will produce airflow. I am trying to get a general idea if this might be something simple like a fan that needs to be replaced, or if I am in store for something more costly. It is not a problem this time of year, but I live in South Florida so when summer rolls around something will need to be done. Any thoughts are appreciated???
Drunk Devil is offline   Reply With Quote
Unread 07-05-2006, 02:39 PM   #2
btb601
@002 Wranlger
Last year I took my Jeep into the dealers and had them look at it. It was doing the same thing. They said there was a part taken off and they replaced it. It worked a little better. You could play with it and get it to stay in one position. Now that it's hotttt again, it mostly wants to blow cold air thru the defrost vent and if it's not doing that, it blowing out buy the feet. Anyone have any ideas??? Thanks.
2002 4.0 Sport, 5-spd, Dana44 w/ Detroit Electra Locker, 4.5" R.E.- L A Lift, Old Man EMU Shocks,TrailMaster steering Stab, 5 Hellcats 10x15s, Good Year MT/R 35x12.5s,Warner Frt bumper/grill guard, Warner 9500TI winch, Tomken Rear Bumper and Carrier, Tera 4to1, SYE + CV drshft, Tomken Rock Sliders, , KC Titanium Lites
btb601 is offline   Reply With Quote
Unread 07-05-2006, 04:57 PM   #3
Dudewayne
bad blower motor
bad HVAC control on dash
Does the fan do the same thing in other modes....while the heater is on...etc ?
'97 TJ Sport 5 Speed Soft Top and Half Doors, Sliders
Rubicon Spings and Shocks and 31x10.50's
Dreaded 3.07's GONE !! NEW 3.73's !! Front Dana 30 Rear Dana 35
Red Jeep Club Member #350
"I DON'T SUFFER FROM INSANITY....I ENJOY EVERY MINUTE OF IT !!!
Dudewayne is offline   Reply With Quote
Unread 07-05-2006, 08:27 PM   #4
btb601
I not sure if it does the same thing while using heat. Because I put it on defrost for heat anyway. All I know is it cannot make it blow in the same place. I move the air position switch to a setting and get something else or something new. My Jeep is haunted and I tired of driving a hot $30g Jeep.
When I can get it to work, I will run the jeep for a few minutes going down the road and set the fan to low and then set the air to regular air vent and let it set for a few seconds and then slowly move up to max cold air. Then set the fan to max. If it is not to hot out , it will work. Then most of the time if I am doing 70 plus on the freeway, it will cut out to defrost till I slow down.
