AC/Heater selector switch - JeepForum.com
post #1 of 5 Old 03-07-2012, 03:07 PM Thread Starter
04TJ-jeeper
2014 JK Wrangler
my knob to select which setting (not the speed) has always been that it doesn't "click" at each setting, but rather just works on the defrost mode and the first a/c mode.
if anyone has had (and fixed) this problem please leave some input, is it something that i need to buy a whole new panel for? or is it something behind my panel in the dash?
THE RULES OF LOGIC ARE BENT ON TWO OCCASIONS, MAGIC SHOWS AND MILITARY WORKING HOURS
04TJ-jeeper is offline
post #2 of 5 Old 03-07-2012, 03:57 PM
JBTJ
It's called the mode switch and needs to be replaced.
JBTJ is offline
post #3 of 5 Old 03-08-2012, 10:24 AM
rockingcm1
Pull the knob off and make sure it's not broken where it slides over the shaft. It's a common problem.
rockingcm1 is offline
post #4 of 5 Old 03-08-2012, 01:11 PM Thread Starter
04TJ-jeeper
2014 JK Wrangler
ok thank you, i guess i'll be ordering a new one today, and thanx for the tip about making sure that it isn't broken but i can switch it between the very first setting (the a/c one) and the windshield defroster which are on completely different sides of each other so i know it's turning it
post #5 of 5 Old 03-08-2012, 01:24 PM
JWebber
I would dougle check the color coded lines running to your vacuum actuators. and see if your getting a vacuum there.
JWebber is offline
Heater/vent selector problem Morpheus TJ Wrangler Technical Forum 2 09-24-2011 08:51 PM
Fan speed selector switch khoward1972 TJ Wrangler Technical Forum 3 02-07-2011 06:43 PM
does the heater mode selector switch have a small ball bearing? Bill_Dunnigan TJ Wrangler Technical Forum 2 11-15-2009 08:29 AM
97 tj heater box selector broken @ armature holdenjeeps TJ Wrangler Technical Forum 1 07-26-2009 01:29 PM
Heater Selector Knob Acting Up paracletehigh TJ Wrangler Technical Forum 1 06-28-2009 12:34 PM
