AC/heater blend air lever? Part # for 05 LJ - JeepForum.com
post #1 of 4 Old 09-04-2012, 05:00 PM Thread Starter
jlemond
Hey guys, I broke what I believe to be the recirculation door actuator. Does anyone know the part # and where to get it for an 05 LJ. Thanks in advance. Also I can not figure out how to upload the photo using my phone. It must be too smart for me... So here is a link to my Flickr account where you can view it.
http://www.flickr.com/photos/jklemond04/
It is the black lever that connects between the white arm and other black lever all inside the red circle. Photo courtesy of user Gunkle.
The difference between men and women- "If a key opens many doors, it is considered the master. If a door is opened by many keys, well that's a bad lock."
Last edited by jlemond; 09-05-2012 at 01:35 AM. Reason: Found the correct name for the part, Still no part #
jlemond is offline
post #2 of 4 Old 09-04-2012, 08:16 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
It’s hard to tell for sure but go to http://www.jeep4x4center.com/knowled...ex.htm#service , then find the parts manuals & go to section 24-110. It is labeled RHD & #12 but in the LHD the part is not identified. I don’t know if that is the part you need. Maybe a dealer can help. I doubt that type part will be anything but a dealer only part. Good luck. You may have to make something, I’ve read where some guys have had to do that for some of the small parts like that.
Rubi4MyMrs is offline
post #3 of 4 Old 09-05-2012, 01:37 AM Thread Starter
jlemond
When I go to the site it does not give me the option to look at RHD Jeeps. Can you post a direct link to what you are viewing.
jlemond is offline
post #4 of 4 Old 09-05-2012, 10:53 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
2 different pages, 24-105 & 24-110
http://www.jeep4x4center.com/jeep-pa...ts-Catalog.PDF
Hevac Unit, RHD
Figure 24-110
Hevac Unit, LHD
Figure 24-105
ac , blend air , heater , lj , tj
HELP! Heater problem NOT THE BLEND DOOR! crimson_carnage TJ Wrangler Technical Forum 15 11-20-2010 09:37 AM
heater lever not going to cold merwin7 TJ Wrangler Technical Forum 4 04-28-2009 03:56 PM
Heater lever stuck pastime TJ Wrangler Technical Forum 11 10-07-2008 07:03 AM
97 TJ Heater/AC vent control lever Appello TJ Wrangler Technical Forum 4 05-28-2007 08:21 PM
Heater lever Mike Davis YJ Wrangler Technical Forum 4 10-21-2006 10:30 AM
