Quantcast AC/Heat Blower Switch Melting - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > AC/Heat Blower Switch Melting
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 09-20-2008, 03:22 AM   #1
Stasis
I have now been through 4 ac blower speed switches (and of course you have to buy the entire HVAC unit). The plastic internals of the switches keep melting to the point that the contacts shift and the switch is damaged beyond repair. I have tried replacing the blower fan however this last switch melted no longer then 2 months after swapping out the blower. I didnt think the resistor would be at fault because if that isnt working right it still shouldnt put out more then the highest speed voltage, am I wrong with that? Also this time I havent been using the highest speed (4) just in case, but today it melted position 3, the rest still work but obviously there is still an issue. Please if anyone has any idea what could be causing this let me know, I have already spent over $400 trying to fix this...
2001 TJ Sport 60th
RE 4.5 Suspention Lift
Detroit Rear Locker
35" MTs
Stasis is offline   Reply With Quote
Old 09-20-2008, 03:50 PM   #2
Stasis
anyone have any idea?
2001 TJ Sport 60th
Detroit Rear Locker
35" MTs
Old 09-20-2008, 03:54 PM   #3
RavenCorax
1988 XJ Cherokee
i see a few options replace the resistor cant hurt to try. and follow all your wiring back if you can clean all your grounds.
in all 3 xj's ive worked on all the switchesand plugs were melted we think one of em actually caused a dash fire in my nephews jeep.
2 door cherokee
I wave
RavenCorax is offline   Reply With Quote
Old 09-20-2008, 04:15 PM   #4
Stasis
Wow, it gets hot enough and the plastic looks like it boils, I could see it causing a fire which is not good! Living in Arizona AC is essential though. They need to do something about this if it is that common of a problem! I am sick of buying these switches when they just keep melting, what a poorly made switch too...
2001 TJ Sport 60th
Detroit Rear Locker
35" MTs
Old 09-20-2008, 08:20 PM   #5
Stasis
Anyone have any idea where the grounds for the fan switch are? I checked all that I could find near by but not sure if its the right one...
2001 TJ Sport 60th
Detroit Rear Locker
35" MTs
Old 09-20-2008, 08:58 PM   #6
JBTJ
The problem is with the wiring that jeep uses, to small of a gauge wire for the job. The blower motor bushings wear out in time, causing the motor to pull more current than the switch can handle. (Melted switches and wires) Adding a relay between the switch and the blower motor resistor WILL fix the problem. Mine started with the third speed setting and moved up to the fourth setting. I added two relays, one for each of the highest settings. This is how you can fix it once and for all.
Parts used for the mod so far are: 40 amp relay, relay socket, some 12 gauge wire, solder, heat shrink, and a few 10-12 gauge butt connectors.
The wire for the 3rd fan speed is light blue on my '01 TJ. I cut this wire just past the switch. I extended the switch side of the light blue wire with a short piece of 12 gauge wire which I connected to terminal 85 of the relay, this provides the signal to energize the relay. The other side of this wire goes to the resistor block, I extended it with a short piece of 12 gauge wire that I connected to terminal 30 of the relay, when the relay energizes a ground will be applied to the resistor block through the light blue wire. 12 volts is needed for the relay to energize, I got this from a 12 gauge wire that I ran straight to the battery and connected to terminal 86 of the relay. I've connected a long piece of 12 gauge wire to terminal 87 of the relay, this will get attached to a good ground somewhere under the dash. That should complete the installation. I've burned out position 3 on the switch twice and I hope this will prevent that ever happening again. I may even go ahead and throw a relay on position 4 as well. Positions 1 & 2 don't see as much current as either 3 or 4 and should be fine without the mod.
JBTJ is offline   Reply With Quote
Old 09-20-2008, 10:59 PM   #7
Stasis
Thanks for the info JBTJ, mine is a 01 too but my wires are always fine, just the plastic in the switch melts in no time. I just replaced the blower motor with a brand new one so it shouldnt be pulling more power then normal. Nice schematic there but I dont think I am good enough at electronics to follow that...
2001 TJ Sport 60th
Detroit Rear Locker
35" MTs
Old 09-21-2008, 05:39 AM   #8
EdwinALink
yeah thats the right way! but i dont have the time to do all that. so i bought the switch, some connectors, cut the pignose out of the harness, spliced it in... and tell my passengers that if they put it on the highest setting they may kill us all with a fiery death!
EdwinALink is offline   Reply With Quote
Old 09-21-2008, 05:40 AM   #9
EdwinALink
also, is there a trick to putting that switch in the back of the control panel? it was extremly hard to get it in on mine!
Old 09-21-2008, 02:10 PM   #10
Border Dave
Here are a couple links that may interest you.
http://www.gotjeep.net/article.php?num=13
http://www.jeepsunlimited.com/forums/showthread.php?t=392809
There used to be the website that described how to fix the bad ground problem with the system, but it appears the website is no longer up. If you use the relays described in the above link you shouldn't have anymore problems.
Border Dave is offline   Reply With Quote
Old 09-22-2008, 04:49 PM   #11
Stasis
Cool, thanks for the info. Too bad Chrysler doesnt fix it themselves for real...
Anyone know a good, cheap place to order factory parts online? I found that they do now sell just that switch, part number 5011214AA.
2001 TJ Sport 60th
Detroit Rear Locker
35" MTs
Old 09-22-2008, 05:16 PM   #12
Border Dave
http://www.moparpartsamerica.com/partlocator/index.cfm?siteid=214583
Old 09-29-2008, 02:27 PM   #13
A2SuperCrew
My blower fan switch seems to be on it's way out too. Yesterday in the afternoon the fan would not work at all. Both fuses are OK, and the blower motor resistor is brand new. This morning, the fan works fine on all speeds. This is the second time it's done this. I guess it's a warning! I ordered a new switch from Morris 4x4 to have on hand. It was only $21 delivered. Looks like I have a little project for next weekend already!
2000 Jeep Wrangler SE 2.5L Automatic
Black Jeep Society Member
2005 Ford F250 Lariat FX4 CrewCab PowerStroke 4x4
Trail Rated for Michigan Roads!
A2SuperCrew is offline   Reply With Quote
Old 09-29-2008, 03:49 PM   #14
Goose346
Hot Rod Jeeper
Goose346's Avatar
You can buy just the switch - there is no need to purchase the entire pod. Cost is about $22. Mopar sells over 12,000 switches per year.
Goose346 is online now   Reply With Quote
Old 09-29-2008, 05:40 PM   #15
Oman Jeep
If memory serves me right, I popped the front black plastic of the white base. That let me install the switch shaft at an angle then rotate it into place.
Oman Jeep is offline   Reply With Quote
Glock Forum
