AC doesnt work - compressor kicks on then off - JeepForum.com
post #1 of 15 Old 07-20-2010, 08:30 AM Thread Starter
mystangt
My girlfriend just picked up a 98 TJ with AC, however the AC does NOT work
When you turn the AC is, the compressor kicks on and the clutch spins for a brief second, then stops. Then after 3-4 seconds, it kicks on again for a second and stops right away. It keeps doing this but the air is still HOT in the cabin.
What could this be? A bad compressor clutch or could it possibly be that the system is out of freon, causing the compressor to shut right off?
THANKS!
mystangt is offline
post #2 of 15 Old 07-20-2010, 08:32 AM
newbs
Jeepaholic
Sounds like low freon to me
newbs is offline
post #3 of 15 Old 07-20-2010, 03:47 PM
Pringles
Agreed, low freon.
Pringles is offline
post #4 of 15 Old 07-20-2010, 03:49 PM
tjsean0308
x3 have the refrigerant level checked also could have a leak.
tjsean0308 is offline
post #5 of 15 Old 07-20-2010, 04:13 PM Thread Starter
mystangt
I am going to buy the freon in auto zone...where do i connect it to re-fill it?
and which do the TJs use? 134 right?
mystangt is offline
post #6 of 15 Old 07-20-2010, 04:18 PM
tjsean0308
Yep 134a stay away from the leakfinder added snake oil types just get the good old 134a add it to the low side ( there are two different fittings for the high and the low, the can you buy from autozone will only have the low fitting plug and play) when you have the truck running and the a/c "on" this will probably make the system function but it will be hard to tell if you have overfilled or under filled the system and the success may be temporary. I recommend having it put onto a machine.
post #7 of 15 Old 07-20-2010, 04:20 PM
drstephennix
Yes, 134 and it connects on the low pressure line. there is a, usually black, screw top on the line that you take off and attach your can of 134.
drstephennix is offline
post #8 of 15 Old 07-20-2010, 04:22 PM
cajunfireman
x2 on the machine. If it does have a leak and is low, then it'll need to have a vacuum pulled on it once it's fixed.
2000 Jeep Wrangler Sahara
Firefighter Jeep Club Member #337
"Greater love hath no man than this, that a man lay down his life for his friends." -John 15:13
Fight Crime....Shoot Back
I'll keep my money, my guns, and my freedom. You can stick the change up your ***.
cajunfireman is offline
post #9 of 15 Old 07-20-2010, 04:24 PM
drstephennix
Some of the cans nowadays have a pressure guage on them. you can stop inserting 134 and read the pressure. They work pretty good
post #10 of 15 Old 07-20-2010, 04:29 PM
tjsean0308
in my experience most of those types of cans either have leak detector or stop leak additive or the gauge is about as accurate as a one handed blind man in a shooting contest. And I would definitely stay away from the stop leak it can plug up components real quick making for a expensive repair. also with only one gauge you can't see what the pressure difference from the high to low side is. I really recommend a qualified tech for a/c repair. Its worth it in the long run.
post #11 of 15 Old 07-20-2010, 05:08 PM
wushaw
Rockin jeep
wushaw's Avatar
in my experience most of those types of cans either have leak detector or stop leak additive or the gauge is about as accurate as a one handed blind man in a shooting contest. And i would definitely stay away from the stop leak it can plug up components real quick making for a expensive repair. Also with only one gauge you can't see what the pressure difference from the high to low side is. I really recommend a qualified tech for a/c repair. Its worth it in the long run.
x2
wushaw is offline
post #12 of 15 Old 07-22-2010, 10:13 AM Thread Starter
mystangt
Thanks for the advice gents.
I have never dealt with freon before, and considering that i am a little skeptical as to why its empty, i will go ahead and have a shop do it. It'll be an extra few $$$ but it'll be safer and less of a headache.
Thanks everyone!
mystangt is offline
post #13 of 15 Old 07-23-2010, 01:46 PM
tjsean0308
our pleasure, best of luck let us know how we did on the Diag.
post #14 of 15 Old 07-24-2010, 05:31 PM
chris142
Having a low side guage is completly worthless w/o a high side guage. You can have a green or blue pressure on the low side with only a low side guage and dangerously high high side pressure and not know it.
To do things correctly you should recover what refrigerant is in the system, Pressure test it with Nitrogen to find leaks, fix leaks, evacuate and charge with a scale. The proper charge is very important with a R134a system.
This is why shops charge so much to do AC recharges. A shop must buy a $4000 machine that charges the system correctly.
Some do it yourselfers do get lucky and get the charge close enough to work ok. (+ - 2oz or so). Most guys dont get that lucky and end up overcharging the system. It will not be colder if you add too much refrigerant.
I've had cars come in that are specked for say 1.5 lbs and I've pulled 4lbs out of them!
chris142 is offline
post #15 of 15 Old 07-24-2010, 06:14 PM
Stu Olson
Stu Olson's Avatar
IMO, reading only the lower side without reading the high pressure and referencing both readings to an ambient temperature chart for that system is not worth the time/effort.....assuming one doesn't actually cause damage to the system while filling in this haphazard manner. And as was stated, this assumes the $1 gauge is even accurate.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
ac , a/c , tj , wrangler , compressor , broke , broken , failing , freon
4wd doesnt work newjeeper369 YJ Wrangler Technical Forum 2 02-11-2010 04:47 PM
4wd doesnt work tonylax48 YJ Wrangler Technical Forum 6 06-28-2009 05:04 PM
4x4 doesnt work? Jeepoffroad YJ Wrangler Technical Forum 5 08-17-2008 04:46 PM
4wd doesnt work bkeast17 TJ Wrangler Technical Forum 4 09-11-2006 11:08 AM
Sanden Compressor Clutch work on a York Compressor? Stricken TJ Wrangler Technical Forum 2 07-15-2004 12:55 AM
