AC Delete plate/Idler Pulley - JeepForum.com
post #1 of 11 Old 10-09-2006, 12:45 PM Thread Starter
scorpionkill
scorpionkill's Avatar
My AC compressor started making a HORRID noise today (sounds like toasted bearing or something) I am just going to say screw it and yank the compressor as winter is on it's way and the thing leaked anyway.
Is there a good aftermarket AC delete kit available?
Thanks
2008 JK X 2 door, 1997 TJ
scorpionkill is offline
post #2 of 11 Old 10-09-2006, 01:28 PM Thread Starter
scorpionkill
bump
post #3 of 11 Old 10-09-2006, 02:25 PM
RLD831
RLD831's Avatar
Why would you need an A/C delete kit? Couldn't you just unplug the compressor? If you didn't want it to spin, you could even leave it bolted in and get a smaller serp belt.
RLD831 is offline
post #4 of 11 Old 10-09-2006, 05:25 PM Thread Starter
scorpionkill
Can I just run a non AC serp belt on the jeep and call it a day? The compressor is just about locked up. Or should I take a string and measure the size and match it up as close as I can?
post #5 of 11 Old 10-09-2006, 05:37 PM Thread Starter
scorpionkill
Does a non AC 1997 4.0 have the alternator in the spot of the compressor? If so I can go to the JY tomorrow to see if I can find a non ac alt bracket.
post #6 of 11 Old 10-09-2006, 07:43 PM
Stu Olson
Stu Olson's Avatar
As far as I know the '97 and '98 components setups are the same. This should help....
http://www.stu-offroad.com/engine/belt/belt-1.htm
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #7 of 11 Old 10-10-2006, 08:28 AM Thread Starter
scorpionkill
Thanks, Stu
post #8 of 11 Old 10-10-2006, 09:01 AM
RLD831
RLD831's Avatar
I would just use a non ac belt and leave the rest right where it is until you decide to fix it. The alternators are in the same place with or without ac.
RLD831 is offline
post #9 of 11 Old 10-10-2006, 10:09 AM
lupinsea
lupinsea's Avatar
Had the same problem you're describing and I just swapped out the AC belt for a non-AC belt. Cost about $24-ish and I still have my A/C pump in there if I ever want to fix the pully (pulley bearing went out, too). Of course, it's been about 2 years now with no A/C but I haven't missed it up here in Seattle.
- Jay
lupinsea is offline
post #10 of 11 Old 10-11-2006, 07:38 AM Thread Starter
scorpionkill
Fixed it last night by using the non-AC belt. Thankfully Jeep didn't do what other car manufactures do and move the alt on non AC models. It was a simple belt swap, even though the tensioner puzzled me for a few minutes (never saw one like that before).
thanks everyone.
post #11 of 11 Old 10-11-2006, 10:51 AM
lupinsea
lupinsea's Avatar
I can't remember but I think the pre-00 or pre 99 tensioners are different. With the one on my engine its spring loaded with a 1/2" square hole in the tensioner arm. . . just stick a 1/2" ratchet wrench or breaker bar in there and pull back. Easiest dang way to work with these serpentine belts.
- Jay
lupinsea is offline
4.2L Idler Pulley oct7brian YJ Wrangler Technical Forum 10 02-12-2006 10:32 PM
Idler Pulley vertresq YJ Wrangler Technical Forum 5 12-29-2005 07:46 PM
Idler Pulley kixinc YJ Wrangler Technical Forum 0 11-16-2005 04:26 PM
Help...idler pulley, P/S pulley, serpentine belt? BaltimoreJeep YJ Wrangler Technical Forum 23 02-17-2005 02:33 PM
Idler Pulley Hero TJ Wrangler Technical Forum 2 06-04-2003 07:48 PM
