ac compressor question - JeepForum.com
post #1 of 4 Old 01-18-2004, 07:53 PM Thread Starter
la9
I've noticed a clicking noise under the hood. Turns out out the a/c compressor kicks on spins a few times and kicks off. No certain timing to it. Is this normal ? The a/c is in the off position when it does it ?
Thanks
la9 is offline
post #2 of 4 Old 01-18-2004, 07:57 PM
gelu65
I believe the A/C system is designed to do this to circulate oil thru the system so the seals do not dry out and start leaking. Jerry
99TJ 4.0 5 spd OBA york with underhood air tank,on board welder,110 vdc power, cb, K-N w/4inch intake tube mod, hi lift
gelu65 is offline
post #3 of 4 Old 01-18-2004, 08:01 PM Thread Starter
la9
Thanks for the information Jerry
la9 is offline
post #4 of 4 Old 01-18-2004, 08:31 PM
Darkus
It's cycling on and off constantly? That's what it does when the coolant pressure is low. You can fix it yourself with a $20 can of R-134 w/ sealant which you can get at an auto parts place, or, if it's a fairly new vehicle, it may be covered under warranty. If you top it off, and it starts making that noise again soon after, you might want to take it to an A/C place to have it tested for leaks.
Darkus is offline
ARB compressor question? TealJ87 TJ Wrangler Technical Forum 0 08-13-2008 11:12 PM
A/C compressor question pcm0725 TJ Wrangler Technical Forum 2 05-03-2008 11:10 AM
TJ + ARB Compressor = Question Mowmer TJ Wrangler Technical Forum 3 03-18-2008 07:00 AM
Compressor question Photojeep TJ Wrangler Technical Forum 4 07-23-2007 12:22 PM
ARB compressor question virgil_likes_rum YJ Wrangler Technical Forum 3 05-15-2004 08:23 AM
