AC compressor disconnect - JeepForum.com
post #1 of 7 Old 02-04-2007, 09:24 AM Thread Starter
stedwest
I started a thread yesterday, about switches to replace my knock-outs... Thanks to all.
What I have in mind, was to put a switch in-line with my AC relay, allowing the defroster to run without the compressor engaged... anybody done this?
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
stedwest is offline
post #2 of 7 Old 02-04-2007, 09:26 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
dont see why it wouldnt work, not like it is needed, unless they changed the entire system for units w/and units w/o a/c
RnEmOvr is offline
post #3 of 7 Old 02-04-2007, 09:35 AM Thread Starter
stedwest
This ain't Atlanta, so humidity is rarely a problem... besides, they're were about a billion vehicles built with defrosters, before they invented A/C.
I thought I'd try interupting the ground, off the relay, to disconnect the compressor.
stedwest is offline
post #4 of 7 Old 02-04-2007, 09:36 AM
RnEmOvr
RnEmOvr's Avatar
something try as a "easy check" is just ppll the plug on back of compressor, then turn defrost on and see what happens, my 99 doesnt have a/c but still has defrost
RnEmOvr is offline
post #5 of 7 Old 02-04-2007, 11:13 AM Thread Starter
stedwest
Pulling the plug off the compressor would do it, but I want a 'low amp' solution.. there-fore I need to interupt the relay circuit.
stedwest is offline
post #6 of 7 Old 02-04-2007, 12:01 PM
BlueFlame
BlueFlame's Avatar
Pull out the HVAC control panel.
On the back of the selector switch is a (I believe) 2 wire connector. All you need to do is cut one of the wires and bring the ends to a switch. You can then choose switch ON - normal operation, switch OFF, no AC. What you are doing is preventing the PCM from seeing an input calling for AC. A small round push-on/push-off switch cleverly located in the control panel could even look stock. Careful to make sure it doesn't damage any circuit when you drill the hole.
BlueFlame is offline
post #7 of 7 Old 02-04-2007, 03:41 PM
timc
Yes -- my TJ has aftermarket AC and it runs when in certain positions on the selector dial. I put the switch in mine because I do like to run standard vent air when sitting in traffic with the top down and doors off. In this situation, AC seemed pretty dumb. Still kinda curious if a different AC control panel (from a '99 or '00 jeepw/stock AC?) would connect OK in my vehicle.
timc is offline
To Disconnect or Not to Disconnect... that is the question. JeepMoch TJ Wrangler Technical Forum 7 10-07-2008 09:41 PM
A/C compressor coverted to air compressor rwcook49 YJ Wrangler Technical Forum 9 09-13-2006 02:31 AM
Sanden compressor or electric compressor? Collins72 TJ Wrangler Technical Forum 3 11-15-2004 05:38 PM
Sanden Compressor Clutch work on a York Compressor? Stricken TJ Wrangler Technical Forum 2 07-14-2004 11:55 PM
A/C Compressor convertion to Air compressor E_ROCK YJ Wrangler Technical Forum 3 07-02-2003 06:06 PM
