Quantcast ac causing problems- why is my ac causing my jeep to cut off - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > ac causing problems- why is my ac causing my jeep to cut off
Old 08-07-2007, 09:04 AM   #1
cvaria
Bacon addiction is real
cvaria's Avatar
why is my ac causing my jeep to cut off?
I have an 02 tj se and it idless rough and does insane things when the ac is on. the ac unit itself is on the lamb. the knobs are not accurate. i have to fiddle with it to get the ac to turn off. what is going on?
cvaria is offline   Reply With Quote
Old 08-07-2007, 09:06 AM   #2
Unscathed
What are you idling at without the AC on?
Best Axles and service you will find. http://www.alljeep.com/oscommerce/index.php?cPath=32_617
The owner of Alljeep.com, Wayne Hartwig will work within your budget!!! He is very informative to anyone not knowing much about axle work and will meet or beat any competitor's advertised price on any specific product delivered to your door - even if he sells at cost!
Unscathed is offline   Reply With Quote
Old 08-07-2007, 09:15 AM   #3
cvaria
cvaria's Avatar
<p> rough below "1" and sometimes it will just cut off if i take it out of gear while driving and i'll have to use the gas petal to start it back up. (happened on the expressway too). if i down-shift through the gears to come to a stop it will temporarily behave but eventually cut off. i noticed that it was the ac doing this when i got frustrated and just sat in the jeep one day when it had gotten out of control. i noticed that the ac switch was on the little jeep with the "u" in it. there was nothing going on as far as temp control, just the switch was there. i turned it of and the jeep went back to normal.
Old 08-07-2007, 09:47 AM   #4
Cooneys01TJ
sounds like the engine is starving for fuel....maybe fuel pump
08' Black 2door JK..stock for now, but once I win the lottery watch out!!
O1' Sahara 4.0L, 3.73 gears, dana 30 front, dana 35 rear, 32"X11.5" BFG All-Terrians, 15"x8" American Racing steelies, 2" Skyjacker lift, sunrider top...SOLD
Cooneys01TJ is offline   Reply With Quote
Old 08-07-2007, 10:07 AM   #5
Unscathed
Well idle between 500-800 is normal... rough is not..
I would do the following first before fooling with anything else.. easy first.. hard later.
First, change your air cleaner... (10 bucks)
Second, give it some new spark plugs. (12 bucks)
Do that first.. as you would need to do it anyway for a tuneup.. and post your progress here and we will move on to other steps.
Old 08-07-2007, 10:29 AM   #6
FLATFENDER54
Vacumn leak, need a tune up maybe? Your jeep is supposed to idle up when AC is on (to compensate for the drag the compressor puts on the motor so all in all it will equal out on the rpm guage instead of dropping lower and stalling)
Sounds like it may not idling up and like you have 2 problems or more
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i225/FLATFENDER54/Off%20raod%20trip%20to%20Colorado%20with%20son%20a nd%20dad/DSC01873.jpg
66 Chevelle(Not a good pic in shed 4 many years)http://i73.photobucket.com/albums/i225/FLATFENDER54/memeorystick512262.jpg
93 ford lighting-trick flow heads 6 psi supercharger http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01636.jpg
1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01301.jpg
99 escort zx-2 my favorite lil gas "sipper" (who cares)lol
USMC "Semper Fidelis"
FLATFENDER54 is offline   Reply With Quote
Old 08-07-2007, 10:42 AM   #7
Big-E
My vote is Vacumn leak.
Big-E
Louisiana
2000 Sport
Big-E is offline   Reply With Quote
Glock Forum
