AC blowing hot--temp dial in cold, but temp dial was previously in hot - JeepForum.com
post #1 of 7 Old 10-15-2008, 05:27 PM Thread Starter
greendot200200
The other day I used the heat in my 2000 TJ and the following day I used the AC. When I activated the AC the temperature dial was turned all the way hot from the previous use, so I then turned the temperature all the way down cold, but the blown air never got cold. I tried several things:turning the AC off and reactivating with the temp dial at the proper temp, turn the vehicle off with the AC on and temp dial at the proper temp and then restart and different combos of the prior two and no matter what I did at the moment the blown air was always hot. I had to shut the vehicle down over night and the next day the AC worked properly. I tried my situation out in my XJ and the blown air switched over to cold. Can someone please tell me what is wrong?
Thanks
greendot200200 is offline
post #2 of 7 Old 10-16-2008, 06:44 AM Thread Starter
greendot200200
bump de bump
post #3 of 7 Old 11-13-2008, 04:52 PM Thread Starter
greendot200200
Any one got any ideas on this one?
post #4 of 7 Old 11-13-2008, 05:08 PM
thesherm
thesherm's Avatar
i was going to say your cable might be disconnected but you ruled it out when you said that it went back to cold by turning the jeep off and on.
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #5 of 7 Old 11-13-2008, 05:18 PM Thread Starter
greendot200200
Hey, thanks for the thought. This is a weird one. It's almost like a flap/duct or some sort of air guiding device isn't flipping over. Thanks tho.
post #6 of 7 Old 11-13-2008, 06:17 PM
CraigJenkins1
The tj jeep uses a variety of ways to control the ac and heating. You checked the cable its conneted to the lever but what about the mount for the cable sleeving? Is the red mounting thingee conected to your controller? As far as the vent flap it works by diverting air to either the heater core the condensor. if the cable is not connected properly then this would happen all your other vents besides the cabled one is connected by a vacuumm line which drives pneumatic switches.
CraigJenkins1 is offline
post #7 of 7 Old 11-14-2008, 06:26 AM
baggerman1
Heater
My first thought is to check to see if your actuator motor located under the lower half of the heater housing is working. Unlike 97-98 models which were cable controlled for temperature, beginning in 99 and up through 2006 on the TJ, temperature was electronically controlled. When turning the temperature knob on the instrument panel, this (for lack of a better term) sends a message to whats known as an actuator motor underneath heater housing on the passenger side. Depending on which way you move the knob(heat or cool) will tell this motor to "swing" the blend door located inside of the heater housing. Sometimes when the temp knob is turned all the way to heat or cool, the blend door gets in a jamb inside the housing and the motor cannot turn because the door swung to much. It is an easy check.
1) Take the actuator loose from the heater housing(2 screws, IIRC) The rod from the blend door will be exposed and see if you can turn that rod by hand. If you cannot, you know it is stuck in one position. Usually, you can take your fingers and free it. However, there are times that using pliers to grip the rod and gently turn will "break it loose"
2) Check to see if the actuator motor is working. Find the actuator motor under the heater housing. Turn the ignition on, and move the temp knob and you can see the motor turning.
baggerman1 is offline
A/C Heater Dial Issues BlueTeeJay TJ Wrangler Technical Forum 8 03-25-2012 10:49 PM
A/C Fan Dial eastshores TJ Wrangler Technical Forum 3 08-30-2007 04:59 PM
Dimmer dial doesn't work in my '03 TJ BradG TJ Wrangler Technical Forum 9 03-19-2007 07:57 PM
New Bumper (Dial-up warning) GoGo TJ Wrangler Technical Forum 31 06-24-2005 11:18 AM
Dial Clock rodgersmc YJ Wrangler Technical Forum 3 03-28-2002 09:43 PM
